If You Weren't Allowed A Nissan What Would You Drive?
I never cared for twins but whenever these conversations came up, I always presumed the higher number represented a larger turbo. Learn something new everyday. -
Interesting, I've never seen a failure like that before but with the age of these cars and the general questionable-ness of all kinds of parts these days you can't rule anything out I suppose. Boost leak testing the boost control system would've revealed this though. -
Thanks for updating the outcome; while anywhere in the system could leak, I hadn't heard of a wastegate actuator doing so before, can add that to the list of potentials for next time
Check for blown capacitors, burned traces, cold/cracked solder joints, corrosion, etc. You can try sending the cluster out to a shop that specializes in electronics repair.
