HairyMerkin Posted October 22, 2009 Share Posted October 22, 2009 What fuel? In my town, I have regular, 95RON, and 98RON? Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/ Share on other sites More sharing options...
WESTWD Posted October 22, 2009 Share Posted October 22, 2009 i use BP Ultimate (98 RON) on my R34 RB25DE NEO...i wouldn't use anything else... Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4894438 Share on other sites More sharing options...
N-DAWG Posted October 22, 2009 Share Posted October 22, 2009 98RON would be the best thing you can put in it. I used Shell V-Power for a year, then switched to BP Ultimate when I had the conversion and dyno tune done. Both are good in my experience, never had any issues. Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4894563 Share on other sites More sharing options...
Jack88 Posted October 22, 2009 Share Posted October 22, 2009 +1 for 98 ron. anything less and it will run like a bucket of shit.The fules over in jap land are alot better then ours and thats what it was tuned for. Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4894748 Share on other sites More sharing options...
sydking Posted October 22, 2009 Share Posted October 22, 2009 The 98 from caltex i assume is 98 ron? any difference between that and BP? Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4895241 Share on other sites More sharing options...
BstewyR33 Posted October 23, 2009 Share Posted October 23, 2009 (edited) shouldnt be any differences. some people mention that one is better than the other, put either or in your car, as long as your not getting any pinging, then i wouldnt worry about which brand of fuel you get, just as long as it's 98ron at a minimum Edited October 23, 2009 by BstewyR33 Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4896331 Share on other sites More sharing options...
butch Posted October 23, 2009 Share Posted October 23, 2009 i find with bp and caltex your actually get more than shell. (km per tank) i was stoaked about the differences. the better the fuel . means less periodic maintenance Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4896539 Share on other sites More sharing options...
floody Posted October 23, 2009 Share Posted October 23, 2009 Might as well run 98 but I'd suggest in a pinch, 95 won't harm it. Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4896660 Share on other sites More sharing options...
AYW550 Posted October 23, 2009 Share Posted October 23, 2009 i use BP regular 91, never had any issues, runs smooth, ands gets nearly 600km on a tank Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4896683 Share on other sites More sharing options...
Outrun Posted October 23, 2009 Share Posted October 23, 2009 (edited) Is the tune stock ? If so the 95 from any will be fine (it is cleaner and has less shit in it than 91) If the car has been tuned to run 98 (no cars run a standard 98 tune other than after 2003) then you need to stick with 98, or the thing will ping like shit (detonation) and end up hurting the engine. In my book 98 is the cleanest, best option - even if the car hasn't been specifically tuned to run on it the engine management will make good use of it after a while. Prior to entering the turbo scene i ran a modified LS1 (making 360kw RW) in a VY 1 tonner as an everyday work and play. It had all the frills and was given a birthday (with the upgrades) at around 80,000klms - and up to that point had run on 91. When the heads came off the engine was that full of crap (carbon) and the injection system/inlet manifold was full of pasty, nasty shit that would amaze most. After the rebuild (with dart heads, 10.8 to one comp and stout camshaft) with a new engine management system the ute ran only 98 and was pulled down at 260,000 klms for a tidy up pre-sale. The heads, injection and manifold were as clean as - and the thing had seen a lot of shitty conditions running between Brissy and the Bowen Basin around the coalfields in NQ. fuels aint fuels! - you get what you pay for! Edited October 23, 2009 by Outrun Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4896966 Share on other sites More sharing options...
dori34 Posted October 23, 2009 Share Posted October 23, 2009 ^ run 98RON no matter what. don't be a tight arse annd use 91 or 95 even on stock ecu/tune, much much better for your car. Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4897286 Share on other sites More sharing options...
Reggi34dr Posted October 24, 2009 Share Posted October 24, 2009 I've always used 98RON predominantly BP but with BP servo's diminishing I'm now having to switch over the Mobil's Synergy 8000 or Freedom's E10 Hi Octane 98 as both servo's are on my commute to work. Just got 645K's out of my first tank of 8000. Was getting roughly 620-630 with Ultimate. Am interested to see how Freedom's fuel goes. Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4898160 Share on other sites More sharing options...
WESTWD Posted October 27, 2009 Share Posted October 27, 2009 I've always used 98RON predominantly BP but with BP servo's diminishing I'm now having to switch over the Mobil's Synergy 8000 or Freedom's E10 Hi Octane 98 as both servo's are on my commute to work. Just got 645K's out of my first tank of 8000. Was getting roughly 620-630 with Ultimate. Am interested to see how Freedom's fuel goes. 645k per tank is awesome! im running BP ultimate and im getting bout 250-275 kms per tank...WTF?! Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4902705 Share on other sites More sharing options...
Jack88 Posted October 27, 2009 Share Posted October 27, 2009 When i first got my line i thought yea it will use 91 as every other car normally does. My car ran like absolute shit. would ping its head off had no power and misfired like crazy. so straight back to the servo to fil up with 98 and has beenn runing like a dream ever since. Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4902788 Share on other sites More sharing options...
iseekool Posted October 28, 2009 Share Posted October 28, 2009 For a non-turbo R34 (I'd imagine for all other non-turbo R31, 32, 33 would be the same). You only need 93 RON (shown in the original owners manual and written on the fuel cap) - so 95 should be ok if you are on a budget or if 98 is not available. However... I did notice with 95 I still got pinging, some power flat spots in the lower rev range and the car tended to drink more. I've soley used 98 with no problems. You will still get very slight pinging every now and then on long uphills. I recommend spending the few extra dollars on fuel as opposed to thousands of dollars and inconvenience of engine damage. I wouldn't dare use 91 inless you are really stuck and have no other fuel available - Only use it for "limping" home/next servo that has premium. Link to comment https://www.sau.com.au/forums/topic/293056-what-ron-for-rb25de-neo/#findComment-4904517 Share on other sites More sharing options...
