  • Replies 92
How do you work that out exactly?
We had no issue with Police, never do.
We drove past i think 2 maybe 3 Highway Patrol cars and about 3-4 normal divvy vans - no issues.
If you are not a muppet, you generally are ok.
Yeah, no trouble at all during the cruise, which was cool :D But apparently during it, one of the groups got followed by an undercover, but nothing happened. :)
yeah me soon!, Cass (kamikazininja33) got some, but shes not sharing.
Lol TJ i really didnt, on my honor. my camera was back home in ballarat. If i was dicking around with my phone thats all i was doing :(
All i know is both times i have been pulled over i was doing absolutely nothing wrong.
Guess a bunch of imports is too much to handle
ive been pulled over more times in the GTR then any other car ive driven. only pulled over cos its a sports car. Im always polite and show them respect and they leave me alone. Honestly it doesnt bother me if they pull me over. at least i know they are out there doing what they are paid for
Spewing i missed this ( my membership hadn't gone through by then (i got it the tuesday or Wednesday after) and the cruise was on my birthday :down: sounds like it would of been a good night.
Whens the next cruise happening?
Spewing i missed this ( my membership hadn't gone through by then (i got it the tuesday or Wednesday after) and the cruise was on my birthday :P sounds like it would of been a good night.
Well since you've got your membership already there is a members only (although it might be opened to all now) on the 14th it's an overnight cruise to buller definitely will be an epic cruise
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
