Because they don't crack through the drilled holes like the stock pieces of s%$t.
When I bought mine it had N1 front and rear discs, they were great, no cracking.
Bought some nissan stock drilled discs and 6 months later they were cracking!!
N1 FTMFW!!
N1 FTMFW!!
Thought it might be something like that, but surprised they didn't design something different along the lines of slotted/drilled but without the issues.
I need new front discs and the genuine N1's would be impossible to find so am thinking of just popping in a set of RDA/DBA non drilled/slotted as thats what the car should have. Only prob is I do a few track days a year and if the slotted/drilled are much better for track work, might go with them?
Slotted is OK for racing. Cross-drilled is not. If you have a look, few of the top-tier modern racing teams run drilled rotors.
Dominic Chen from Endless USA did a blog post ages ago. He took it offline due to perceived bias, but its been copied and posted here
Another demerit to the OE system is the fact that the rotors are cross-drilled. Putting aside the cross-drilled-rotors-have-a-tendency-to-crack debate, the issue with them is that they cool too quickly for track conditions. This is a fact that even Brembo themselves will tell you. With rotors that cool too quickly, you get erratic temperatures which cause rotors, both cross-drilled and slotted, to crack.
Also, the inability to maintain a good temperature means that you can potentially drop in and out of the ideal temperature range for whatever brake pad you’re using. The fact that the OE rotors are 2-piece floating allow for the rotor and bell housing to expand with heat, which is good, but the fact of the matter is that the surface of cross-drilled rotors is cooling too quickly.
Obtained my DBA fish-hook slotted rotors with curved vanes (the latter, to dissipate heat) from UAS.
...same as some of the SuperV8 teams as Alan alluded to.
Cross-drilling under high heat renders the disc to cracking at the site of the hole.
This is due to uneven rates of expansion as heat builds juxtaposed to fast contraction in between braking.
Any slots that go to the edge of the disc are also prone to cracking at high heat.
So slots that are contained 'within' the perimeter are better.
just grab the plain (non drilled or slotted) Bobby. That's exactly what i ran on the race car for years (from DBA) before they allowed us to go to 2 piece. they were fine (see avatar :thumbsup:)
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
