Has anyone tried using the snow mode for better fuel economy.
I have noticed it cuts down the boost?
What else does it do?
Also does anyone know why my stag jumps forward if i have the snow mode on and i turn the car off.
snow mode from what i can work out, doesn't use first gear, so it stops any wheel spin.
so if you are stuck in snow, you can pull out with easy.
jumping forward i wouldn't know. but would driving around on snow mode be good for the car ? some whiz will be here shortly to clear that up :P
probably has more to do that it is locking the center diff and causing some binding(windup) of the diffs. It is probably releasing this windup as you turn off the car and it releases the diff lock.
it takes off in 2nd gear like someone else said . a lot less traction brreaking torque than first . i wouldnt drive round with it on the whole time . your just riding the torque converter . how do you see it using any less gas than simpley not using your foot better . ?
sorry it doesnt take off in 2nd gear. its constant 50:50 torque split. and yes ive noticed that it appears to be pushing forward while in one of the synchro modes. but as andy said, its pressurising the atessa system.
snow mode limits boost, thats why youre seeing less fuel usage. but please note that every atessa mode on an M35 has full range of the gearbox!!
jumping forward i wouldn't know. but would driving around on snow mode be good for the car ? some whiz will be here shortly to clear that up :)
snow mode doesnt help you get unstuck haha
but yer driving up the mountian with snow mode on i find it hard so slip.. with it off. i am all over the place when i push the pedal a little bit.
my nav unit already as the fuel economy on the screen
Just wondering if anyone knows what snow mode does and weather its ok to drive around using it
short answer: NO.
Snow mode means ATTESA is driving the front wheels a lot. The ATTESA system is not designed as a full-time 4WD system if that makes sense. Basically if you leave it in 4WD mode all the time eventually the clutch packs will burn out and I'm told they are very expensive to replace.
ATTESA is designed to give traction where its needed, but drive in RWD where the extra traction is unnecessary.
The system most likely wont break if you use synchro or snow mode 1 day a week or something like that...but i wouldn't recommend leaving it on permanently. Just puts more pressure and wear on the clutch packs.
This is all stuff I've gleaned from this forum so someone correct me if I'm wrong.
I can only speak authoritatively about the C34 although I believe its the same for the M35:
Snow mode cuts out first gear. I have used it for a while to try to get better economy but got bored with it!
Whatever you do to lock the Atessa has no effect once you get some speed up (I am not sure exctly it may be as low as 30 km/hr) and then the Atessa computer takes over again so I don't see any harm can come from leaving it in snow mode (and I am not even sure that it affects the atessa anyway).
The only reason i thought it might be good is that when im on the highway and hit the snow switch is my boost drops right back and i thought that would cause me to save fuel
You are using boost while cruising on a highway? What speed do you cruise at???
You should be able to get around 11km/L (or better) from a stock M35 cruising at 100kph.
As iamhe77 mentioned, you generally wouldn't be on boost while cruising on the highway. Boost is determined by engine load, not rpm. Unless you're accelerating, the boost guage would likely be showing either 0 or -ve pressure (vacuum).
At 100km/h the revs should be almost exactly 2000rpm when the torque converter is locked (and in 5th gear). To keep it like that, put the gear lever into tiptronic and bump it forward to 5th gear (it will default to 4th when you first move it over from drive but if you move it fowards quick enough the gearbox will stay in 5th). Keeping it in 5th this way will still allow it to change back to 4th at full throttle, but makes the throttle less sensitive so that you wont keep hitting boost etc. You'll find it much easier to keep the revs on 2000rpm this way than when the lever is in drive.
Who cruises @ 100kph?
I sit on 110kph, or sometimes accidentally drift up to 118-120.
Our speed limit is 110 though.
I think you missed the point. Even at 110kph, you should be getting around 11km/L as all the hard work is accelerating up to that speed, not maintaining it (unless uphill/ headwind etc)
try taking it to 120kph, then backing off and gently applying a light foot to maintain 110kph. You will be amazed how different your economy is (especially if you can control your right foot after holding your desired speed) when compared to accelerating up to a certain speed and holding it.
I believe you are referring to the torque converter lockup which will occur if you do this. Often it wont lock until you lift the throttle just slightly. You can tell its locked because the revs will drop by about 500-600rpm.
Putting it in 5th using tiptronic helps because otherwise I find it keeps boosting which causes the torque converter to unlock again...
At 110 (118 on my speedo - 110 measured by my portable satnav) my revs are normally around 2300.
A satnav will give you a more accurate speed readout than your speedo provided it has a good signal and you stay at a constant speed.
Interestingly the torque converter on our 5sp auto will lock up in either 4th or 5th gear, when travelling over 80km/h.
I tend to miss the point alot :blush:
Yeah, i get great fuel consumption on highways. I pretty much average 550km a tank now and I have developed a bit of a lead foot. I would get more if I didn't live on a mountain range.
That's a very good point and I will try it out next time on the freeway. Last weekend I drove down to Goulburn and did notice the moment you gas it a little, it would gear down to 4th from 5th and hit boost. While it's great to overtake quickly, it will use more fuel on boost for sure. Nevertheless, I can get about 700kms on a single tank when run entirely on the freeway.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
