hey guys.....was a pretty hot day today in Melbourne and unfortunately had to run some errands in this heat.
after returning i noticed the extreme amount of heat the engine was emitting...to the point i started getting worried. water temps were as high as 95 degrees and oil almost hitting 90.
i have a Koyo radiator that i recently just put on and had no dramas until today. most of the heat is comming from the exhaust housing (top mount gt35r) and there is no heatsheild.
can anyone give me some tips as to how i might overcome these problems? some people have mentioned ceramic coating the front/dump pipes and the exhaust housing. atm ive only got some shonky heat wrap.
any help much appreciated guys.
My oil is usually at 90, today went a tiny bit over due to Aircon on but hardly ever seen it over 90. Last year on those 46-47 degree days it got to a bit over 120 but 90 is fine dude. The water temp is a little high though.
I think properly made heat shields are the way to go , the heat insulation bags around the turbine housing are supposed to be good things too .
Ideally you want to keep the heat in the exhaust gas so it can do positive things for you , heat radiated into an engine bay does nothing for you .
A .
Driving around today, i didn't go past 75 degree's water temp. Every setup i've had has never gone above that either.
No heat shield is your issue, you are crazy to run around without one IMO.
Hmm, what exactly is a heat shield? Are we talking about something custom designed for the car?
I just have a Race Radiators item, it was made for a R33, but we modded the mounts, fits perfectly into a HR31.
That is basically it.
I also use the factory RB26 heat shields, RB26 clutch fan with shroud etc etc.
None of this wanky thermo business, just how Nissan intended it with a good quality radiator.
I have 1x A/C condenser and a radiator sized intercooler directly infront of the radiator as well, so its not exactly getting fresh air either :P
And i wouldn't say i have a massive 'mouth' on my front bar either.
The RB26 does sit lower in a HR31 than a GTR though (ie top of the cam gears is level with my radiator top), but i doubt that is anything major in terms of reasons.
Being he has a high mount, yes it will be custom made for the exhaust housing.
Usually just a 180degree bend of stainless that bolts on. Not hard for a fabricator with half a brain.
Cheers,
I was having trouble with mine last summer but i never knew because the factory temp gauge didnt move much. It wasn't until the tuner plugged it into his pc and took it for a drive (diagnosing another problem) we noticeed it around 90 degrees). Since then i have played with the clutch fan and have noticed a lot more air being pulled through.....i just have to wait until its back on the road!!!!
James
PS: I also have a 4.2EFI patrol that is nearly identical in the engine bay minus the turbo. I plugged my consult thingy in and noticed when the factory gauge is on 1/4 its 84 degree (sits there on normal driving) and 1/2 is 89 degrees!!!
Nismo thermostat worthwhile or not whats the general consensus
rebuilding my rb26 at the moment an wondering if its worth the extra dollars
2530's poncams etc etc was making 429 hp before it spun a bearing so big baffelled sump etc going in now
found with stock rad an nissan clutchfan etc it kept temps under control well before even on trackdays etc in Darwin heat!
Edited by noone
I hated mine... made it almost impossible to get the car up to temp on cold Melbourne nights but you might not have that problem in Darwin!
90º water and oil is fine... no reason to stress out
while were having this talk .i thought id ask.can u run an aftermarket 50m radiator and still keep the clutch fan in place? and dose the 26 clutch fan make much of a diffrence?????
Cant answer your query regarding the 50mm rad though I am pretty sure they will fit okay
Nissan clutch fan and correct shroud was so so much better than thermofan on my 32
that plus an oil cooler and I really didnt have to worry bout temps on track even in Darwin temps
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
