Everyone wants something different...thats why we get body kits and big ass turbos and fmics and sht like that...
im interested in something different aswell....
i was thinking of putting the rb26 head on my rb25....
i have been told that it can be done but you just have to change some water jackets or something....
i pose a new question.....can a R34 Neo head be put on our block and get the more advanced VVT system? :cheers:
im not a mechanic and im learning as im going
thanks for any input... :O
ps. i presume i would need an r34 eco too...
https://www.sau.com.au/forums/topic/29546-bang-for-buck-something-different/
Hey Fane , talk to Steve @ SST , he and Grant (Per4manz) have flow tested heads b4. I have heard that a flowed 25 head can outflow stock 26! Also , saw an RB26 head on JMS website for $2000!!! After all that , a stock turbo isn,t goin to get the most out of a flowed head IMO.
Cheers :cheers:
The Neo head has nothing to offer. The RB26 head would perhaps offer a better starting block for a big power setup, mild it's a serious waste of money for $2k.
A bang for buck mod looks like the 264 deg exhaust camshaft with a stock intake cam based on some computer sims. Upto 50hp over the standard and up everywhere over the rev range without any sacrifice to off boost.
My car is a few days from completion.Engine should be fully assembled and in engine bay by today. We will see how the computer sim works in real life.
thanks alot rev210
i was hoping you were going to reply...
this is a very future mod...and the 26 head is looking a bit more appitising....but i'll be doing the whole lightened flywheel and crap like that first....
just dont want to do stuff that cant be used if i do a future mod...if you know what i mean... :)
ps. GL with your car dood, pics?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
