Almost there, just have to fit sideskirts on Monday, then fit the wheels to give it the stance.
Colour is a bit trippy depending on daylight and night lights in the workshop...
Will post pics once it rolls out to the street
Best angle shot for the car
The Phatt Guards
Shot of the rear end with the 400R Rear Bar
At midnight under factory lights its gold...ewww
Under normal daylight in the factory...different?
  • Replies 66
Have you flared your rear guards yet? You cannot say it's a widebody until the rear and fronts are proportionally flared...also, to give it the fat look, you have to get a GTR spec bonnet and GTR spec front bar...all this adds to the new fat look.
Your colour is unique mate...I call it the Caramel colour! lol Nice!! I wish you chose the GOLD look ....actually looks nicer in my opinion!
quick question for those checking this, mines a GTS-4 so its awd setup...now the front hubs that i got from a gtst dnt suite and wont bolt up for my 5 stud conversion
anyone have any ideas how to fix this, im lookin in ur direction kevin :blink:
anyone have any ideas how to fix this, im lookin in ur direction kevin ;)
Hey mate...I gotta give up here mate...cannot help you there...suggest you post a new thread in the suspension or drivetrain section.
With my GTS4 it came with 5 stud wheel conversion already done - I just turboed it and that was it. Not to demotivate you, be honest mate, after all that hard work...looking back, I think it was cheaper to just go and buy a GTR.
However, if you can build a GTS4-T into a monster then it just adds to the fun! :(
As you know I now have two cars, a GTR and a GTS4-T - I gotta say, I do have a soft spot for my GTS4-T as it was with it that I had spent so much time and money.
Go for it buddy!
Edited by Spunky Munky
Nuh after this build I'll be heading towards and Audi S3...this is just my toy project to get it out of my system as I always wanted to build a car.
As for 5 stud conversion already worked it out I just need a set of HNR32 or BNR32/33/34 knuckles front hubs and Im all good from there.
Dnt worry I realised I could buy either a Nur or N1 engine from Just Jap and have dropped the engine in with the amount I've spent so far...but I did bodywork...so eh its already been done. As I said I'd have always bought a GTR but I wudnt have been able to drive in for 3 years cause I'm on my P's still til next August...
Here's some of the new photos
http://www.skylinesaustralia.com/forums/Wh...0&start=800
As for focusing on the flares, what sort of shots do you want?
This is the rear guard from PSI Parts
Once fitted and blended into the guard
First coat of highfill
Shows the width of rear guard paint/fitted
Looking back at the guard
Anything else let me know mate
  • 2 months later...
Hi Daniel - haven't been on here for a while...great to see your car has been finished and is now on the road...looks good buddy...
The colour is (as I had predicted) - changing a bit, getting darker which is tough as it was too yellowy at the start for my liking - looks really good mate.
Love everything about it - except for the front bar - I suggest you get a Do-Luck front bar and it would complete the look nicely.
Looking good mate - so what's next?
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
