Im looking at running my R round a track in a couple of weeks, what are the basic things to do before I go?
I have read about overfilling the oil for the day, but how much?
Got good brake pads and fluid.
Will check tranny level.
Anything else?
Will the stock turbos be ok with the restrictor removed or should I put it back for the day?
https://www.sau.com.au/forums/topic/296683-r33-gtr-basic-trackday-prep/
With ceramic turbos you want to run the least ammount of boost as possible to prolong the life of them, if you have steel wheel turbos then knock yourself out. I overfill to the kink in my dipstick, but otherwise have a read of the other trackday pre threads, also might be worth borrowing a windeband o2 sensor or getting a dyno run done to make sure the AFRs are safe.
Cheers guys.
I had a bit of a search around before I asked but couldnt find much (except the oil control thread and Im not gonna pull the engine to put an extra oil drain on it!)
I have the stock turbos so stock boost it is.
How much should I overfill the oil? I have read it should be up to the hump in the dipstick but is that when hot or cold?
yeah about there, that is generally 1lt more.
even more important is to put in good quality brake fluid like motul rbf600. totally bleed the old stuff out until you see the new stuff running through (careful not to run it dry while doing this)
check all fluid levels (might take all day, gtrs have a crazy number of fluids).
since its hot make sure you have bleed the coolant properly.
if you are going to do more track days, consider adding an oil cooler. if not keep it to 3-5 laps flat out, or 5-8 laps at 80% (which is all most people manage on their first track days)
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
