To be honest, all Honda people think that, typical Honda speak, i don't mean to generalise but that's the reality
As far as the comparison, i really don't think the 4th gen Prelude will match up to a GT-V - which has better low down torque, LSD bigger brakes than the standard 25GT model
The only Prelude i think will give an R34 a run for its money is a JDM 3rd gen V-tec Prelude with mild mods, mate of mine has one with Mugen Extractors, pod filter and full X-force exaust and he's pulling 110kws atw, bearing in mind they are also 1100kgs
Edited by squareznboxez
I hate these threads but I love posting in them, go figure. Just go and do the drag race already. On paper though, the Prelude will win in a dash off the line. In a rolling drag from 80km/h...might be more even / in favour of the Skyline. Just look at the 0-100 times of them both. VTi-R Preludes are no slugs by N/A standards. And squareznboxez...Preludes are more like 1350kg from memory.
Stats don't mean shit unless your racing brand spankn new cars straight from the factory, maintenance plays a big part in comparing used cars, If a cars had a hard life then i think its fair to say it will certainly have less power and torque than what it had brand new. Even if a car has 50hp more than another car on paper it doesn't necessarily mean its going to be the fastest, might have low compression on a cylinder and have a f(*ked piston or something.. lol.. You never know who will win until you race. :)
oh boy another of these threads.
Go to a race track/drag strip and find out.
Too many factors as the guys pointed out above.
Also transmissions, mods and driver skill - Launching a FWD prelude is heaps harder than a RWD skyline.
Pointless thread really.
Who's di(k is bigger
probably be a close race and come down to who gets the better launch. sure the fwd is a bit harder to launch, but they aren't that hard but the honda's aren't exactly torque monsters so wheelspin is less of an issue. go and try and launch a manual 3.5L magna and you will find it a bit harder.
both cars being dead stock and with a decent launch from each vehicle i think i would probably have to put my money on the honda though.
and skyline owners talk the same was as well. basically it's the same shit with a different brand. nearly every fan boy is going to say that their car is faster than a different make, reguardless of whether it actually is or not.
I also agree with this...
Fan boys piss me off
Sorry my mistake, the curb weight of 4th gen Preludes are 1280 kg, which is the one my mate has, the JDM V-tec versions had the same power from the factory as a R34 25GT, assuming your mate's one is the more common ADM non V-tec model i think your car will be much better.
5th gen Preludes are even worse unless you have a JDM Type-S
With the fanboy statement i think Honda fans rate their V-tecs much more than any other car fans rate their NA or turbo cars
My Supra is faster than both. ;)
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
