hey guys
i just changed the turbo on my r32 gts4, i put in a R33 turbo that was rebuilt and hiflow'd! also using a justjap slipt dump pipe(screamer)
car was running perfectly fine! the turbo lines were just all cut off and a hose fitted and tightend.
coolent is flused and new. car runs fine as it is without steping on it but then when i step on it within like a minute or so the temp gauge starts going up high!
When the car is turned off i can hear the water boiling.
Nothing is leaking!
hope someone can help so i can resolve this problem!
thanks
https://www.sau.com.au/forums/topic/297629-changed-turbo-and-now-overheating/
hmm strange...
explain this?
you mean to say your running a water cooled turbo, without the water lines attached?
you have not bleed the cooling system correctly. you should fix this ASAP before you damage your engine.
If you are unsure how to do this, take your car to a mechanic who knows how to bleed skylines and get it done properly.
hey guys
Nothing is leaking!
thanks
You might have an air lock in your cooling system for when you flushed it. If so, try starting your car with the rad cap open. keep it open even afther the thermostat opens. this way the bubbles will eventually go away. Hope it help!
Cheers!
Take it all the way out. It pays to turn heater on to get the air out of the heater system aswell. Water will trickle out when the air is out. It does take a little while for the water to come out okies.
take it somewhere to bleed it if you arent sure, you could easily have your temps over 100 degrees without even knowing it.
if you INSIST to do it yourself the steps are:
- start the car with the radiator cap off, keep topping it up till its filled.
- turn on the heater to the HOTTEST setting and run it at its maximum speed.
- loosen the bleeder till its around 1 thread till its off and keep it there till its completely bled.
- keep going till no bubbles come out of the bleeder.
you can use some kind of funnel type thing (see below) to help it along.
i dont have a bleeder on mine, i do the old 'put on a sealed bottle to raise the highest point of the cooling system' trick. works well, car bleeds pretty quick. you have to block off the overflow hose for it to work properly though.
I changed the coolant not long ago in mine... I did all the things security has mentioned.... thought all the bubbles were out, took it for a drive and on the pfc it was telling me straight away that the temps were going up... went straight back home (only got down the street) i let it bleed for 15 mins which i thought was enough.... ended up taking like 30 mins with the heater going full.... so how long did u bleed urs for?
you replied 30mins after i posted - i highly doubt you did it right mate.
i wait there, squeeze both of the radiator hoses continuously as im topping up my funnel thing - it just helps get ALL of the air bubbles out. i suggest taking it to someone who knows what theyre doing.
Mate dont risk f**king your engine up, dont touch it unless you know exactly what ya doing, take it, wait, and pay a proffessional mechanic to do it the right way, then you can get that piece of mind and sleep like a baby.
dont mean to sound like a dickhead, but i dont want your car to blow up :)
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
