Hey you guys! I'm a newly registered member, even though I've been reading this forum for a year. I'm from canada and the imports are finally making their apperance in a muscle car world lol. I'm finishing university in 2011 so I will be able to import an GTR R33 1996 (15 year rule). I've been reading alot and I have my build all planed out (almost) I juste want you honest opinion about power, drivability, response etc.
GTR R33
rb26
Forged internals
New bearing
Gasket kits.(looking for a good compression 8.5-8.4 opinion)
tomei cam with a 260 duration (suggestions)
Head work (valve porting)
Fully balanced(crank etc)
ajustable Cam gear??? like the old 4 degre advance key in a v8 350 which you can ajust
full Exhaust 4" (if not good correct me)
Garrett 2860-5's (yes I'm running twins)
Apex fc computer (or which one is the best)
Intercooler(heard that the stock one would be good, if not please tell)
Tomei oil pump
Bosch fuel pump (dont remember which one, but like the 044 or something. Ill do resesrch again lol)
Splitfire coils
Do I need an external wastegate or these turbos have the internal wastegates. And if the have the internal wg, should I upgrade to an external wg. I would redirect the exhaust for the wg back in the exhaust (reduce the loud noise)
600cc injector (1cc for 1 hp)
dig. boost controler
PLEASE TELL ME WHERE I CAN GET A ROCKER COVER that says NISSAN GTR I've been searching for 2 months lol no joke (I have attached a picture)
Do I need an upgraded fuel rail?
twin plate clutch
The tranny should hold up. If not should I upgrades the 1-4 gears(syncs).
Does the (fuse removal) technique really works with the tranny. If so, does it damage anythings will being in rwd mode
Will the stock cv shaft hold up
Should I get the V-Spec version for the lsd?
The suspension will be upgraded also(meaby a suggestion... I'm looking for a good street use that can be stiffen for track. 98% street 2%(if that) track
The come with brembo brakes- Are the as good as the say?
We dont have tracks in eastern Canada (New-Brunswick)
My town is called Bathurst. Just like the famous race track in the 90's in your country!! Pretty cool lol
I'm looking for the nice 6 spokes rims. You know which I meen. If you know the brand please tell. Looking for 18's Gold. Car will be black.
Engine bay will be painted black with a candy apple red engine color.
I just want a red engine with ss intercooler piping, the rest will be stock.
I think this is pretty much it. I probably missed something somewhere but thats ok lol.
How much AWHP/WHP will I be making 550?
How much PSI should I be running. ( I read that 1.6 bar is that these turbo's like)
Response: When shoud I see 1 bar 1.6 bar (correct me)
Gas mileage... Just kiding. I would pay for dice lions to run this car lol
Thanks mates!
Nick
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/
GTR R33
rb26
Forged internals
New bearing
Tomei oil pump
Splitfire coils
twin plate clutch
Thanks mates!
Nick
Forgot to ass the Z32 map or maf? please help here
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954311
Some of my suggestions:
Try ACL gasket kits
I would ditch the Power FC for a Vipec or maybe a haltech….but it depends on the tuners you have there if they are unfamiliar with these products the result wont be as good, so maybe ask your tuner of choice what he likes to work with.
The Turbos have internal wastegates, no need to upgrade to external
No need to upgrade fuel rail
Don’t remove the 4wd fuse on a R33 GTR, they have a preload to the front diff so they are never truly RWD, if you remove the fuse you will prematurely wear the transfer case, The R32 is the only GTR where the fuse removal trick works
The Non V spec diff to my mind is better being a proper mechanical diff, maybe get it shimmed?
For suspension look at the Sydney Kid group buy in here and get something similar
The intercooler should be fine
The wheels you are looking at might be Rays TE37s??
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954517
To start, 550rwhp = 410rwkw.
To attain this you are going to need a serious build to get it out of the -5's. They can do it, and have done so before, however it is not a case of putting in parts and you magically make the power.
You need to ensure the block is prepped correctly or you will split it (ie filling with concrete in the right spots).
Most of golden tricks to making the power lies in the head and porting/modifications, you've made very little point to any head work and honestly i think you'll struggle.
480-500rwhp sounds like a more realistic & achieveable target for you, which pretty much every -5 equipped motor makes without too much trouble.
Its the last 70rwhp or so that requires the development knowledge of RB's and what makes the power.
You comp ratio is also too low. But that depends on what fuel quality you guys have over there (i have no idea)
The turbos have internal gates, that do not need upgrading/mods, you really should know that kind of info mate if you are planning on a build.
Also you cannot run in RWD mode by pulling a fuse, you MUST remove the shaft that drives the case.
600cc injectors are too small IMO, ideally you want the next size up which is around 700-740cc from memory. A bit of headroom is never a bad thing.
Otherwise your list looks pretty much spot on, although i hope you have very deep pockets. You won't see change out of 30,000AUD.
You'll get plenty of PowerFC haters, but at the end of the day combine it with Nismo AFM's - and in the hands of a GOOD tuner you won't have any problems at all.
You'll also get a lot of 3ltr bandwagoners as well, which is something you sound like you do not want.
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954519
my advice. I know it's fun planning out all the builds etc, and there is not much else you can do I guess without a car. but I would just start with buying the car. enjoy for a while as it is. you don't need 500hp straight away and the budget to do it properly is going to be tripple the value of the car.
the coil pack cover you want which says nissan GTR is from an R34 GTR, they are just a stick on plate. you can buy one for about AUD $120 or so.
personally get the non vspec if you can as you can cheaply buy a kit from nismo for the diff which will give you a proper 2 way LSD for about $300AUD + fitting.
seriously, things change fast. no point planing the build now without the car. buy the car when you can. enjoy it for a while and THEN see what you want out of it. :D window shopping your ultimate build is fun but in the end not really much help.
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954741
Powers FCs are good, but they are getting long in the tooth and are way over priced. for similar money now you can get better
and he didnt way he wanted 550whp he just wanted to know what his set up might make :D and the answer to that is who freaking knows!
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954744
oh yeah i didnt see that he didnt have the car yet...as some one who is going through a rebuild now i can say it isnt a lot of fun so i would drive the car for as long as you can rather than take it off the road as soon as you get it
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954747
Well he asked "will i be making 550rwhp" with a "?", so it was a question, of which the answer too is not quite as simple as yes or no.
Many factors to take into account before saying either way :)
A PFC is less than $1,000 deliverd brand new.
Any other solution comes in at at the least $1,500, typically $2,000.
About as far from similar as it gets in pricing terms when something is double the price.
The time old argument of 1000 auxilary inputs means nothing.
You do not need 15 data logging points, 20 additional sensors etc etc unless you are in some form of racing.
A PFC is priced for its features, just like any other ECU, and for a street car - more than adequate. That does not make it long in the tooth at all.
And to hammer the point home there are HEAPS of GTR's running around the circuit, hillclimbs, targa, 10 sec or less drag cars etc etc with the 'lowly' PFC.
So they can't be all that bad in the hands of someone capable
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954822
yeah they are $1000 then add in $350 for each Z32 and the price isnt that different, and my main beef isnt the auxillary inputs its the lack of comparitive mapping resolution and the fact that over the years airflow meters have caused me nothing but dramas
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954852
Same with other ECU's, some you need to buy high pressure map sensors and so on depending on the ECU choice/application/needs etc.
AFM issues are just like any other sensor though. I do agree they can be problematic. I've had trouble with mine on the RB26 setup.
However this was due to me being a tightass and getting 2nd hand ones - 100% my own fault for buying 10yr old ones... as with most sensors 10years seems to be about the time when they start play up.
Mapping resolution point is again, racing. You don't need that stuff for a street car. But as i said, it plenty of competitive motorsport people can run, and win events, with a PFC it clearly shows mapping resolution has all of zero to do with it.
Overall though it's horses for courses. You simply pick the ECU your tuner wants to use, and go with that first and foremost to get the best results.
If you don't need a swag of extra features - that you have to admit are arguable in being 'required' - then the PFC is a clear winner.
If you feel you need extra mapping points or whatever, extra inputs, logging - then you will need to look to other ECU's on the market at a higher cost.
I take the assumption he knows his needs, and hence chose the PFC. If im wrong on that assumption then fair enough.
Side note: i think bosch AFM's are about $200-250ea from a contact i have, ive been meaning to try them see if they are the same.
Something i'll get around to one day... lol.
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954869
I have previously agreed with everything you say
The power FC is fine BUT you must admit there is better to be had as even in a street car having more load points can give a nicer result HOWEVER like you say if the tuner has no experience with the other ECUs out there he would be better off with the power FC as every one is now pretty familiar with them.
Would be interesting how the Bosch AFMs compare!
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954882
Thanks guys for your comments!!!! Thank you for your time. Just so you know :) lol I plan on buying the car in 2011 and drive it for 7-8+ year before doing a complete overhaul. Over the years i'll get the stuff and the skylines are starting to make their appearance over here.. so there will be alot of wrecks that I can salvage Nice. I was really a v8 guy all my life. My father build a 71 Pontiac GTO (frame off restoration) an 72 Nova etc. So it grew on me pretty fast lol. But I've comme to appreaciate the quality of japan engines and the work of their enginners... It's almost an obsession :S lol Anyways I really like your comments the were very helpful.
P.S. I'm french(canadian) not "quebecois" (if you might know what it means lol) so I don't write well sometimes lol.
Cheers!
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954883
Just for facts:
Or highest octane is 91 and 92 some places. I heard that its not the same rating systems as you guys (octane)
Our import laws are 15 years. Mostly of them are located on the west coast of canada (vancouver) because its close to japan(duh) We start seeing R32 and more Gtst r33. A couples of guys in my town are buiding 240sx(k24a something motor) 150hp n/a but swaped in a rb25 with an gt35r top mount. Pretty nicem he did a lot of work on it. We dont live in igloo's lol
Cheers!
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954915
Apexi Power FC is an aftermarket computer that has been around for ages.
I agree its got a lot lesser feature when comparing to the new ecus but I also agree with Ash on how many of those feature would you need as a day to day street car. The cost of tuning would be a lot cheaper as they're a lot easier. I just got told by a fellow qld sau-er that my tune was a lot cheaper than his (he's using dejetro). I was told the same thing by 2 other reputable tuners before this. Maybe the vipec would be cheaper?
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4954981
Beer Baron, I've got an R34 gtr non vspec and was wondering if a similar diff kit exists for the 34??? If so do you know where I could source such an item? Sorry for the thread hijack...
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4955049
wow wot a waste of a thread, he says the build isnt even gona happen for 7-8 years.
unless u are actually in the process of obtaining parts to start the build its pretty pointless
so much is gona change in that time, and u probly wont even end up buying a gtr
my 2 cents
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4955238
my 2 cents
So you dropped by this thread to say this? Very constructive.
https://www.sau.com.au/forums/topic/297635-gtr-r33-build/#findComment-4955265
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
