what I mean is, $1000 on a vid card when it is probably something I may upgrade in a few years is a bit pricey...
as it seems anyway, I got the best card I could... no 295s in stock anymore either...
  • Replies 115
case = thermaltake armor +
PSU = 1000watt corsair
CPU = i7 920
ram = 6GB Dominator 1600
2 HDD's = Falcon G Skill2 (SSD's)
vid card = EVGA GTX295 Co-Op
mobo = EVGA X58
water cooling gear = blocks for cpu, mobo and vid card... pump, radiator etc
plenty good and plenty of room for later upgrades :D
The only thing there that isn't basically the best of the best is the CPU (overclock ftw) and the Mobo... but I don't feel like spending $700 on 4 way SLI that I'll never use.
With the exception of the case, reads as a nice build especially for O/C
For $1500? Not a lot...
There's some watercooling gear that comes with the case, but like I said, I'm replacing most of it. I think all that will be left is the pump, even though I want to replace that too, just no stock of the swiftech pump... so really, that leaves the built in reservoir.
sooo... what should i be buying?? :D
A computer.
You don't have the budget for a specialist machine for your intended purpose. You could get an older version of one of the workstation cards but in your case I'd get an i7 with 6GB ram so if you do get a workstation card later it will be worth it.
i dunno, say... $1500? Want to get it through my dad's work whilst the tax/rebate thingy is still kicking around
actually, that maybe bump the budget up... it's 30% isn't it?
FYI: Provided your dad's work turnover is less than $2million the tax break is 50% if purch before 31 Dec '09 then reduces to 30% there after till the end of next year. So, if that's any help in bumping up your budget to ~$2K, than it could be feasible for said workstation and with Quadro card.
The other option if your IT litereate you could soft mod a gaming GPU to emulate the equivalent workstation card but afaik there's only a select few cards that have been successful (eg. Nvidia 8800 series).
i7 920
ud3r
6gb gskill 1600
5770 or similar depends what u can get ur hands on
case what ever u want
blue ray combo drive
1tb hdd
1 ssd for OS
done
g5 and g15 for keyboard and mice or something similar
Where would I buy 5970 from in the states that ships internationally? And for a total cost of $700?
http://www.tilatech.com/ is where I've imported stuff from before and they were pretty good, so random that they sell rims now as well. There are a couple of others or you need a third party if you want to purchase from newegg as they don't ship to Australia and don't accept international payments.
What about those no name cases? China Cars?
Made out of the same stuff, possibly similar panels.
Edited by DivHunter
I don't see tilatech.com having ANY video cards, let alone stock of the 5970... So with the fact that it's more expensive, f**king massive, doesn't have many or any watercooling blocks, and that I can't even find one to buy, I'm going to stick to my 295 choice :D
Which by the way, was waiting for me at work along with everything else.
lol @ complaining about no water blocks on a car that has JUST hit the market.
EK will have blocks out in less than a month. Usually does.
There might even be a thread on it @ xtremesystems - sometimes he posts designs and whats coming etc
A US website that one of the guy from work here uses all the time is www.provantage.com Some prices are comparable with Newegg.
I dont entirely agree though with the posts mentioned before about us being ripped off and HEAPS cheaper in the US.
Honestly, please prove me wrong as I wanted to use provantage to get a gfx card but by the time courier costs and the dollar difference is added it is only a $30 saving when i was looking at a 4890.
Plus i was always told with electronics if it is not a huge price difference buy local as it is much easier to organise returns etc. The further away the harder it gets.
Again if i am wrong please let me know as I would love to find some good cheap gfx cards :-)
$30 here, $30 there - buy the time you add it up over an entire system build mate you are looking at probably $200-$300 on a $1500 system.
When newegg etc have some of their pricing deals - you'll see $50-$70 saved on a $400 item at times based on pricing here.
That could virtually put a nice SSD into your case or something that would really offer some good benefit
EDIT: also take into account you are paying single item postage. These guys are bringing in containers which are comparitably speaking are much cheaper again.
So if its $30 AFTER postage, it would be what... $35-$40 - which now brings you closer to $400 on a $1500 system give/take.
Overall that ain't a bad saving and clearly shows businesses here gouging pretty hard.
New release items are worst though - 5970 as the example
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
