Took it to the track today on Federal 595 SS. I am going to a sprint meeting in Stanthorpe on the weekend, and with rain forcast I want to know what they are likely to do.... They squirm and load in a really scary way in the corners and under brakes. However the are good for straight line grip and drifting on.
  • Replies 119
Posted Images
I really can't complain, there a 235/45/17 which we get cheep for drifting on. bang for buck there a good thing.
Playing with intercoolers today, the old 1 had a fair bit of damage on it from the last 7 years of use and lots of abuse. Tested it on the dyno, 310rwhp on 1Bar. Not bad for a streeter.
Went to Stanthorpe for the Short Circuit Supersprints this weekend. 2nd in class (Improved Production) and 3rd outright. Pretty happy with that, only beaten by an FC RX7 Sportsedan and a 510rwhp commodore Improved Production car. Not bad for number plates.
Edited by Noddy
starting to look at the race car shell, looking and thinking about engine placement, "V"mounting the intercooler/radiator, steering/geometry and so on..... which to tackle first? I'm thinking engine first the fit all i around that. Or cross member?
  • 1 month later...
I'm sad to say, the motor is out and in lots of pieces. Not for any bad reason like a spun bearing or anything like that. In a nut shell, the rings have been a concern of mine pretty much from the start.
When I built it at Christmas, the Oil control rings just wouldn't sit properly, they would bind up to the point that they really didn't fit. I ended up using the old spring, 1 new scraper on the bottom and an old scraper on top. Not ideal but it got it all back together. This has played on my mind since the beginning. I have decided after an airlock overheating event, to replace the rings and head gasket (which was reused as well), and give everything a good look over. Every thing looks pretty good, excellent even, that is other than the rings, they definitely look 2nd hand. The bore is spot on, thank God. Te exhaust manifold has cracked in the same place, again, so I'm getting Mercury to make a new 1 for me, Just couldn't be bothered making it this time.
What I have found is that ACL had ROSS in the US. make the pistons with an odd ring size, so you had to order through ACL to get new rings. Turns out that some one decided that was a dumb idea and changed the specs to a regular commonly available size of ring, ACL they no longer stock the odd size rings. Luckily ROSS do stock them.... I think, I've ordered a set in the hope they are correct for my pistons. The most confusing thing here is, there is only 1 part number on the pistons, even though there are 2 different ring specifications.
Waiting for the postman takes soooooo long.
Edited by Noddy
  • 3 weeks later...
  • 3 weeks later...
Got the car to a meeting this weekend, last round of the Preston Peaks, Qld v NSW SuperSprint series at Carnell in Stanthorpe. Came 1st in class and 2nd outright. I got beaten by a WRX sportsedan, this is his run at bathurst hillclimb
He set a new standing start super sprint 4 lap reccord, 2min, 19.57 sec. I got close.... 2min, 21.48sec. Not bad for a car that is my daily with a full interior.
So with the series now over, I have won Imp prod over 3L and the series outright. :worship::):D
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
