Great vid!
It was interesting to see his hand positioning around the steering wheel, especially when he needed to change gears mid corner.
Would love a translation of when he passed the R8 with its hazard lights on. Probably started with "get off the racing line you ..."
https://www.sau.com.au/forums/topic/299882-epic-battle/#findComment-4983654
Love that circuit!
Another one.
<object width="425" height="344"><param name="movie" value="
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
https://www.sau.com.au/forums/topic/299882-epic-battle/#findComment-4984612
he was just driving with one eye in the rear view mirror!
I got that too. He made a fairly good getaway down the straight only to almost run off the road at the end
because he wasn't paying attention to what's in front. Apparently one of the GT-R punters comments that "he's going
to kill himself".
He's also using some fairly defensive lines and running wide on the exit.
I get the feeling that there has been some fairly intense rivalry between these two drivers.
https://www.sau.com.au/forums/topic/299882-epic-battle/#findComment-4984621
Wow, magnificent video! It's obvious that Italians like the GT-R too! (bit of a suprise there)....and it's obvious there is some rivalry with the F430 Scuderia guy too!. Videos like this really put into perspective just how incredible the GT-R is, not only does the F430 Scuderia weigh alot less, it's a track special with Carbon Ceramic brakes...and it was under brakes the Gt-R was closing in!.
Both cars are awsome though, I'd love to have both!.. There will be times you want the GT-R's crushing ability, there will be times you want the Ferrari's glamour and engine/exhaust note!
https://www.sau.com.au/forums/topic/299882-epic-battle/#findComment-4985559
Great vid!
I picked up some but sounded like "why doesn't this idiot get out of the way"
https://www.sau.com.au/forums/topic/299882-epic-battle/#findComment-4986803
Kujotk, being of Italian background, I can translate for you.
When he went past the guy in the Audi R8 he literally said "have a look at this!"..obviously said in such a way that suggests "have a look at this idiot"
https://www.sau.com.au/forums/topic/299882-epic-battle/#findComment-4991094
    • Jax Tyres this Monday morning. Front lifted 15mm Back lifted 12mm Quote1, $175 per tyre + wheel alignment. Quote2, $660 inc wheel alignment. paid $298 for the lot.
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
