hey,
iv recently done a rb30det conversion into my r32, very budget build so the bottom end only got a new set of big end bearings, original mains and oil pump. anyway engine is up and running, runs fine, my issue lies from as soon as iv started this engine iv low oil pressure, i was running 15w40 in it, oil pressure tested at 30psi at approx 3000rpm, 15psi and idle WHEN COLD and 15psi at 3000rpm and about 2psi at idle WHEN HOT.
so i pulled the sump off, pulled out the pressure relief valve at the bottom of the oil pump, it didnt seem stuck or anything, so i cleaned it up to make sure it was sealing well, lubed up well and shimmed the spring abit to hopefully lift oil pressure.
filled with 25w50 castrol edge oil, cranked and now i cant get ANY oil pressure.
i have primed it for awhile and im not getting anything, i searched the forums and i found a thread about possibly having an air lock in the oil pump, so i as someone in that topic suggested, i cut the top off the oil filter, gutted it, filled with oil and wound the engine backward in hope to suck oil into the oil pump and get rid of the air. i didnt it for awhile, probably put atleast 2 oil filters full of oil back thru the engine and i could see it go down as i wound it.
put it back together with the 25w50 and still no oil pressure at all. iv tested with 2 different guages and im definately getting nothing.
so the engine used to have oil pressure, all i did was remove sump, remove and refit the oil relief valve (second time triple checked it was fully closed) and refitted it all again.
only thing i can think of is when i removed the sump, due to very small clearances between engine and crossmember, the guaze on the end of the oil pickup is alittle dented, nothing back at all, still clean, just not perfectly round.
any suggestions what i can check next, now im stuck....??
p.s sump is 3L sump with fins ground down
Looking forward to how you are getting on mate as ive just had the same problem with my engine.
My engine on the dyno recently lost all oil pressure and now reads nothing. Will be pulling in a few days with a hope to finding out what the issue is.
Are these engines with oil pressure problems running stock cranks and stock bearings? Do you get oil pressure back when you put your foot on the clutch?
When I first built my 30 we didn't check any clearances, just slapped it together. Turned out the crank had a heap of endfloat which destroyed the thrust washers, scored into the back of the oil pump a good 4mm or so and started to eat the webbing in the block for the main journals.
It was so bad, that you could actually see the harmonic balancer move when someone put their foot on the clutch.
Ended up pulling engine out, crank ground .010 over and a set of matching bearings went in and she was mint. Certainly learnt my lesson there :)
Mine was built by an engine reconditioner, however im not too sure now how good the job was. My engine has ACL race bearings with stock crank. I replaced the release bearing the week prior due to it being noisey, however i think that was more a problem with the engine sitting for quite sometime.
Your comments are pretty interesting though and certainly could be bang on for my setup. Will let you know once its out.
he means the thrust bearings in the engine (middle crank main), your refering to the throw-out bearing in the gearbox bellhousing.
yeah mine was just a slap together (didnt pull crank out) but i still dont see how b4 i atleast had some oil pressure, now got nothing at all...
im going to pull off my rb20 one, check it!!!! then if its ok ill put it on and see how we go
Yeah, the thrust surface on the no.4 main bearing :cool:
Mine got gradually worse (as it ate out the thrust bearing), it wasn't a sudden catastrophic failure.
So you didn't even freshen up the bottom end? just slapped your head on it?
it got new bigend bearings, but at the time i wasnt going to replace the oil pump, and the crank timing gear was seized onto the crank and i didnt want to damage the oil pump or anything in the removal process, so i just decided to leave it and hope the mains were ok.
very rarly do mains go.. unless the thust is rooted. but you will still get 60+ oil pressure when cold.
if you have only 10 or so pound the head will be very second hand very soon.
can only be a rooted oil pump or wrong bearing size.
  • 1 month later...
thanks guys,
pulled the oil pump off and it was the typical problem, the phillips head screws that hold the plate onto the back of the oil pump had come loose hence was loosing pressure.
put a genuine rb25det ($250 from usa ebay thank you!) and shes pumping again.
thanks for ur help
thanks guys,
thanks for ur help
good work i hope you loctited the new one so they dont do the same thing!
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
