  • Replies 3.6k
Posted Images
MSC..... WTF!!!!!
Cue the race driver excuses. "Err ... I had a brake problem, and there was a misfire in the engine, and something strange was going on with the electrics."
Translation: "I'm too old and I should have stayed retired."
Nice work Capt'n Chin, a good quali time (and another needle in SV).
Big night tonite, Formula1 + GER vs AUS marathon.
I can't wait to see how the tyre battle works out in the first 5-10 laps.
I've got 1.5L of Red Bull to keep me awake :P
Good to see MW giving it his all on his final qualy lap, even tapping the wall of champions in the process, just to stick it to SV aain :ninja:
Red Bull opted to change the RB6’s box as a precautionary measure. It means that Webber’s team mate Sebastian Vettel, originally third on the grid, now joins Hamilton’s McLaren on the front row.
very convenient... wonder if helmut had any influence over that decision???
Felt like saying something similar but restrained myself. Until now
I suppose it would have been more suspect if all would have gone according to plan and then Webber were to conveniently suffer a gearbox failure during the race.
Yeh, i am sure there is nothing to it. But shame is from this point onwards there are going to be those people that just 'have to wonder"
But its one of this things, all the gremlins this season have been in Vettels car so is about time for Webber to share the pain
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
