  • Replies 3.6k
Posted Images
WOW,
I attempt sexy times with Mrs Mike
On lap 3 and I miss Chin flying... Schumie making a poor pit strat although in 3rd for a bit (yesssss)
Then see Vettool nearly throw it away on the restart!!!
What a hack!
Safety car f**ked Ferrari...not quite as bad as it did MS however.
And as much as HK is a tool for defending against a car that is so much faster than him (if in fact he knew who it was coming up on him), that was some amateur-esque shit from Webber...Why draft a car that close when you're going to pass him with ease anyway?
lol, fkn every driver is being called a hack tonight...
fkn hamo, hasn't f**ked up yet at all... what a hack!
Give Louise a chance,
As Sh@un reminded earlier this week
Monza 2009
HACKNESS of Epic Standing!!!!
Did VEttel and Hamo abide by the max speed under pace car. They sure as hell gapped the Ferraris by a massive amount?!?!?!?!?
That's what Alonso is talking about on the radio... I was wondering why he was so far behind when Homo pitted considering they were so close on track before the SC
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
