  • Replies 3.6k
Posted Images
Hamilton must have changed his undies post race after running wide onto the gravel and kissing the wall but he had control of the race so no harm done.
I had massive Caterham flash-backs! LOL
That was the same corner (and same outcome) as I had on my visit there! :P
I read on planet f1 that Horner blamaed Button for breaking early
lol. love it. poor ze-tool. no doubt he came back to the pits for lots of hugs and a cup of cocoa. definitely not his fault. button was braking early (how dare he be cautious into a wet corner that had just caught a whole bunch of drivers out), and then there's the bumps. poor seb. it was only his amazing skill that saved him from ending up on his lid. all that sawing at the wheel under brakes must have helped steady the car.
Sarcasm win.
Watching the replay of the race last night....i ave to echo Davidsons thoughts about tracks these days....with so much concrete run off bad driving is not being penalised. Looking at the end of the first lap, , Hamilton, Button, Vettel, Kubica all went off. Webber stayed on track, ALonso, Rubens etc all went off...there should be a big gravel trap there....you should not have a 20mtrs tour off the circuit in a kink and not suffer a loss of time. Looking at the replay, Webber took the kerb normally and lost time to all those ahead who cut the kerb!
yep, I agree too. the new boys like hamilton and vettel know there is no consequence to little fark ups so they can push hard and when they overstep the mark it's nothing more than a run wide and some pick-up on the tyres. more 'old school' drivers like webber are used to the days where if you came off the track 9 out of 10 times you stayed off the track either in a wall or gravel trap so naturally they drive differently and are being disadvantaged a little.
so yes they should change it. but can they hold off on changing spa till AFTER we've driven there next month? hacks like me need these massive concrete run-offs. it's how i cut my sick laps. otherwise it's into the wall I go....
Yeah, I childishly voiced the hope that the entire field would be penalised and give Webber the victory! But if he'd followed them and made places, he could well have been punished.
I agree that the modern tendency to pave a paddock's width either side of the track does allow drivers to get away with mistakes. But the alternative is to have a safety car every time someone goes off. Well, perhaps not every time, but gravel traps = more SC.
Agreed it's stupid. I saw that and straight away thought they should have been penalised. They may not have 'gained an advantage' but they certainly didn't lose out, and they didn't follow the track
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
