Guy's Cruise Control Stuck On 80 Km/h
http://www.theage.com.au/national/cruise-c...91215-ktxn.html
Holy crap! Did anyone see this? Surely a massive Ford Explorer doing 80 km/h down the wrong side of the road while tooting its horn, with a police escort, would have been quite a sight. Apparently a "known" problem on Ford Explorers :) !!!!
Why the hell would anyone spend all that extra money to import a second-rate American SUV is beyond me. I have rellies and friends in the US, and none of them own US made vehicles as they are generally so crap/unreliable, not to mention potentially lethal!
Jap for me please.
https://www.sau.com.au/forums/topic/300256-guys-cruise-control-stuck-on-80-kmh/
  • Replies 53
lol how does putting it in neutral not stop the car... you take away the transmission, there is no more power being transferred
story sounds like a load of shit.
Apparently he tried that and taking the keys out...
Pulling the handbrake wouldn't do anything if your cruise control wants to go at 80.
I'm not sure how the car can keep going while in neutral though. You should still be able to take the keys out as well. Maybe the Explorer has a design flaw that prevents you from removing the key while the car is moving.
Stagea has to be in park to remove it, but you could turn it back one click, go to far and steering would lock. Not having powersteering wouldnt matter at that speed, no brake boost just means press harder.
Neutral would work best for most people surely.
Ford brought these into Australia for a short while, they aren't (well most) privately imported.
I sense bullshit too. I know of no transmission, auto or manual, that cannot be shifted to neutral by the user at any time. Sounds like the guy was covering his ass on some accounts.
Wtf how would pressing the brakes hard not overpower the cruise control? the car would be sitting at like 2000revs at that point, surely it could be stopped.
Also tried to turn the engine off? f**king stupid idea if he wants no brakes or power steering.
Sounds like a load of shit to me
Hmmm interesting story. Brakes may have gone to shit if he tried turning the ignition off? But still from what I've seen pressing the accelerator, brake or lifting the handbrake switches cruise control off and adding that he tried the ignition that's 4 ways of which he couldn't stop the car. I dun see how that's possible. Also how the he'll did it keep going if it was in neutral? Electric circuit controlling the shifter disabled as well by the cruise control? Maybe they should test this guy for smoking pot that morning or something
Cruise control is designed to maintain speed. If you go up a hill it accelerates to keep the speed. So if you apply the brakes and cruise control is stuck on it will simply open the throttle more. Engines are more powerful than brakes so that part makes sense.
Turning the engine off would be stupid... power steering gone but then the steering wheel would lock (even worse), without the engine on brakes don't function as normal.
The best option by far would be to select neutral. How the driver could not do that does not make sense AT ALL! :cool:
if you turn the key off, and then just back to accessories, the car should not still be running - and without a wheel lock :(
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
