spotted JOELF. this evening at the lights near JB in phillip, didnt see him as he came from my right, but he gave me 2 big beeps, and a wave, thanks for that and nice to see you again.
also spotted a fu**ing parking ticket under my wiper, i paid for a full day parking ticket and displayed it properly in my window, and received the fine because i was a few bays over from the corresponding section, fu**ing vultures! no chance i'll pay it though.
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1049015
Spotted: a black 33, series 2 wing going down drakeford drive at about 7:15 last night. only caught a glimse of the back lights (mmmm hotplates) so i couldn't see if it was a stocker or yeah :D
yea i am pretty sure that was me was at a mates place i was looking for some punk on a bike but couldnt see you lol
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1050138
spotted...someone trying to drive their car into the Kingo lol
if you haven't heard about it, apparently someone clipped an Action bus and smashed into the pub causing 50K worth of damage...happened about 6pm last night..
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1051023
Spotted a purple R32 at my school this arvo at about 3ish. i know it's someones on here, but i cant remember names lol, andrew i think (one of the many)
Yea that was me dude......
I recognised you and waved, hoping youd remember me..
Also spotted Black R32 at Southers Carpark yesterday
Spotted....... Fully cant remember your name sorry mate.... White R34.
Also someone else.... but cant remember.
Yea also.... what do you do when you get a letter in the mail saying
" Notification of suspension to pervisional licence" ? :confused: :cuss: :hellpisd:
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1051129
Spotted - AndrewR33 driving past my place just then - 10:30, looking and sounding good buddy!
do you mean me? i didnt know we had an andrewR33 so i assume you mean me?
where abouts is your place? im guessing somewhere near gordon?
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1051836
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
