spotted JOELF. this evening at the lights near JB in phillip, didnt see him as he came from my right, but he gave me 2 big beeps, and a wave, thanks for that and nice to see you again.
also spotted a fu**ing parking ticket under my wiper, i paid for a full day parking ticket and displayed it properly in my window, and received the fine because i was a few bays over from the corresponding section, fu**ing vultures! no chance i'll pay it though.
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1049015
Spotted: a black 33, series 2 wing going down drakeford drive at about 7:15 last night. only caught a glimse of the back lights (mmmm hotplates) so i couldn't see if it was a stocker or yeah :D
yea i am pretty sure that was me was at a mates place i was looking for some punk on a bike but couldnt see you lol
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1050138
spotted...someone trying to drive their car into the Kingo lol
if you haven't heard about it, apparently someone clipped an Action bus and smashed into the pub causing 50K worth of damage...happened about 6pm last night..
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1051023
Spotted a purple R32 at my school this arvo at about 3ish. i know it's someones on here, but i cant remember names lol, andrew i think (one of the many)
Yea that was me dude......
I recognised you and waved, hoping youd remember me..
Also spotted Black R32 at Southers Carpark yesterday
Spotted....... Fully cant remember your name sorry mate.... White R34.
Also someone else.... but cant remember.
Yea also.... what do you do when you get a letter in the mail saying
" Notification of suspension to pervisional licence" ? :confused: :cuss: :hellpisd:
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1051129
Spotted - AndrewR33 driving past my place just then - 10:30, looking and sounding good buddy!
do you mean me? i didnt know we had an andrewR33 so i assume you mean me?
where abouts is your place? im guessing somewhere near gordon?
https://www.sau.com.au/forums/topic/30059-spotted/page/69/#findComment-1051836
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
