maroon r33gtst stocker at charnwood shops car park tock off like like um well I dont want to offend any one. j/k was it any of us SAU'
i think i saw that one today going on the bridge over the highway near the Mint (soz dont know what the road is called) but it looked similar to the one you described didnt really have much time to study it as i was on the bus home in the opposite direction
https://www.sau.com.au/forums/topic/30059-spotted/page/123/#findComment-1193737
Spotted Leech again this morning :)  Those wheels look good on your car.  Fill the guards nicely too.
Cheers jay ;) yea i am actually getting some king springs and lowering it 1" or 1.5" that should then fill them even nicer :rofl:
spotted black series II with black plates in the car park opposite moose in the city, driver was wearing a blue shirt trying to find a car park, looked like lee :)
hmmm wasn’t me unless someone took my car without me knowing but i haven’t heard of/seen any other black skylines with black plates :) stole the only thing making my car unique
https://www.sau.com.au/forums/topic/30059-spotted/page/123/#findComment-1194298
hey whats with everyone hitting me up for prices for my stuff :rofl:
na i rang up and spoke with steve or chris i think it was from mercury motorsport (i got my last set for the pulsar through them) and yea getting just the low's which as i said i think are only like 1" or so for $250 delivered to canberra :D every place i rang up around here told me i was dreaming cheapest most places could do was about $350. so yea drop em a line and just try your luck its all about bartering :D
https://www.sau.com.au/forums/topic/30059-spotted/page/123/#findComment-1195047
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
