should have got a photo andrew (veilside) that does sound sexy :D
and yea andrew (gts_duy) i figured as much same thing happened on the mighty pulsar :D but anyways a little lower is good as least i am still not going to scrape on anything thats bigger than 1 cm :)
https://www.sau.com.au/forums/topic/30059-spotted/page/139/#findComment-1229939
spotted a hooooot black R32 parked on the side of a street in Narabundah, was slammed, had nice big chromies and an awesome creme int, i hav'nt seen it before, but DAYUM!!!
and an awesome, sky blue R32 (i think GTR) flying up hindmarsh drive just after the tip.
it looked like the one that was sitting at ed's for a few months.
https://www.sau.com.au/forums/topic/30059-spotted/page/139/#findComment-1230011
Spotted andrew in his purple beast doing some hot laps of the main drag in braidwood about lunchtime today...
i also saw the wrx sandwich, did look pretty cool
Hot laps????? more like a stylish drive throu...
Yea saw ya too.... saw the car, then the wheels and thought.. "yea i know that car"
My mate was like.. "wtf??" who, what....??? i just smiled..
https://www.sau.com.au/forums/topic/30059-spotted/page/139/#findComment-1230194
Spotted a silver R33 sitting in the middle of parkes way under the foot bridge. I was walking back from Tropfest and looked down. looked very odd, it was the only car parked there, i hope it wasn't anyone here or that it had been stolen/dumped or broken down
https://www.sau.com.au/forums/topic/30059-spotted/page/139/#findComment-1230659
was the other car a white 33? if so that wouldve been andrew and me going to woden with a white r33 around the same time too, didnt know him and not too sure if hes on SAU but he gave it a good floggin, nice guy though waved and went in our own directions. on the back he had a sticker saying club motor sport or something like that i cant remember, but car was very clean and went abit sideways coming out of the lights near the tuggerz pool i think it was cause he saw us behind him i dunno... but nice car!!
https://www.sau.com.au/forums/topic/30059-spotted/page/139/#findComment-1230833
saw a white 4 door line coming from queanbeyan on lanyon drive this morning , turned off to tuggers, 1st 4 door other then the swish silver 34 in jerra that I have seen.
Yeah seen a white 34 4 door a few times last week around the belconnen area, has a nice set of wheels and looks pretty damn good. Actually its a real head-turner!
https://www.sau.com.au/forums/topic/30059-spotted/page/139/#findComment-1231198
Spotted a p plated honda integra slamming his breaks on behind me, acting like a complete fool... then trying to race me off the line doing full sick burnouts while trying to impress the chicks he had in his car..
Lets just say he didnt get too far, and had to result in a loser flybye:D
https://www.sau.com.au/forums/topic/30059-spotted/page/139/#findComment-1231330
spotted nice gunmetal 32 gtr last night leaving civic at about 3 or 4 something in the morning. was parked outside the canberra theatre opposite commonwealth bank. tints, lowered on nice fat 17s. black plastic plates.
damn the police were out in force last night!!!
d
hey man...yeah that was me, yeah there was cops all over the place, I think it was something to do with the canberra show... civic was packed as :alcoholic
https://www.sau.com.au/forums/topic/30059-spotted/page/139/#findComment-1231393
spotted
sxygtst last wednesday at the servo in fyshwick near EVO.. hungry jacks is there.. you know the one
at lunhtime (12.45??) followin some chicks (tough ****)
might of saw my car..
old green and silver celica in the car park, next to a S4 rx7 and bagged vn ss with vaults.
you see??
https://www.sau.com.au/forums/topic/30059-spotted/page/139/#findComment-1231812
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
