Spotted heaps today.
Black R32 GTS-t on Travener St Oxley at about 10am, then a Silver R33 GTR at Erindale car park at about 12.30pm, and I think it was Bluprint on Drakeford Drive at about 1.30pm then a black R32 GTR on Drakeford Drive at about 1.45pm.
Big day :cheers:
J
https://www.sau.com.au/forums/topic/30059-spotted/page/149/#findComment-1269177
Spotted me getting defected last night, for the funniest thing too.
Enlighten us, A.! I had a heads up text from a goodly SAU'er(thanx Sinista !) that they were out in force;anyone else get "spotted" in a bad way?
https://www.sau.com.au/forums/topic/30059-spotted/page/149/#findComment-1269566
Police van on Monaro Hwy...lights ablaze....followed by our resident pain killer PANADL, followd by a Police motorbike...followe by an XR8 pursuit car...quite odd i thought.
ahhhh someone flogged my car. NOT!!!! bastards empounded my car a bit harsh but cant argue :thumbsup:
https://www.sau.com.au/forums/topic/30059-spotted/page/149/#findComment-1269609
spotted a heap of R33's and Terminals Stagea in braddon, then later on i pulled into a servo just as Theo was pulling out in the R34 Vspec
Let me guess number plate not displayed correctly (attempted fine evasion)
would i be right???
https://www.sau.com.au/forums/topic/30059-spotted/page/149/#findComment-1270046
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
