spotted a black Series II at the lights near woden turnoff on saturday. Only caught a glimpse of the back of it, black custom plates.
might have been me i was out then :) popped in to brian hall motors to see what he had cars look ok but omfg talk about prices :) maybe i should sell mine through him later lol bog stock S2 with like over 100000km's in ok condition $26000 lor $27000 i forget still :kick:
https://www.sau.com.au/forums/topic/30059-spotted/page/162/#findComment-1328868
Spotted a gunmetal with phat dish wheels R32 GT-R on the way home from trivia last night about 10:15pm on Yamba drive
Seriously, it's like clockwork
Every Tuesday night on the way home from trivia, on Yamba drive, I always without fail see some form of GT-R.
Always.
https://www.sau.com.au/forums/topic/30059-spotted/page/162/#findComment-1332890
spotted me sort of accidently cutting of another skyline but he was going a bit quick i reckon coming out of the work car park in dickson @ 5 today had to plant the foot unfortuantly to make sure i got out of his way my poor car :( anyways if it was someone on here sorry :) it was a silver 33
https://www.sau.com.au/forums/topic/30059-spotted/page/162/#findComment-1333329
Always.
Hi Mark, that wouldve been me :bananaman :bananaman :bananaman
https://www.sau.com.au/forums/topic/30059-spotted/page/162/#findComment-1333665
spotted me sort of accidently cutting of another skyline but he was going a bit quick i reckon coming out of the work car park in dickson @ 5 today had to plant the foot unfortuantly to make sure i got out of his way my poor car :D anyways if it was someone on here sorry  :( it was a silver 33
Haha, that was me dude, but you weren't even close to cutting me off. I don't think I was over the speed limit though XD :P
Also spotted a silver series 2 R33 turning onto northbourne next to a white series 5 RX7 later... maybe 7:30ish. :headspin:
https://www.sau.com.au/forums/topic/30059-spotted/page/162/#findComment-1333691
Haha, that was me dude, but you weren't even close to cutting me off. I don't think I was over the speed limit though XD :(
lol no worries you probably wernt going to quick its just a pain in the ass to see off to the left their with other cars blocking half the view :D anyways as i said soz :) i did try and give you a wave :)
ps your car looked nice hehe :P
https://www.sau.com.au/forums/topic/30059-spotted/page/162/#findComment-1333856
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
