I saw those 2 GT-R's for sale as well.
This morning about 11:15, silver R33 GT-R in Phillip with a bit of lively driving, seconds later saw MickGTR on Melrose Drive.
About 12:45, black R34 25GT-t on Tuggeranon Parkway, front mount & mags
https://www.sau.com.au/forums/topic/30059-spotted/page/165/#findComment-1351174
just a word or warning on speeding - but shouldn't be necessary as no one in these high powered skylines on SAUACT speed :)
i've seen a whole crapload of RBTs and cops with speeding guns around. the most notorious one is going across that big bridge into the city, the one before city hill. cops are never there, and the problem is that everyone travels at 70-80 down that road, where it's actually signposted 60.
never seen cops there before, but there was one hidden behind trees with a handgun near the carpark, so watch out.
https://www.sau.com.au/forums/topic/30059-spotted/page/165/#findComment-1351673
Blueprint went around the corner to the parkway just before me when you spotted that Black GT-T. Tried to catch up but didn't want to speed.
But I wasn't speeding......
With the car in the unfinished state that it's in I don't need to be attracting the wrong kind of attention to it :Oops:
https://www.sau.com.au/forums/topic/30059-spotted/page/165/#findComment-1351922
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
