spotted what i think was a defect station at the bottom of athlon drive, outside the electric station turning left onto erindale drive
one lane was blocked off, about 10+ cops, and 3-4 cars left on the side of the road. definately wasn't an RBT station, so my good money is on defect station, careful eh
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1423471
well i dont think mum's sss that i have today will get defected :) i am safe
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1423534
yep saw that as well, as i was heading towards woden...
hmmm i know i have some pickonable stuff.
yeah i'd be done hard methinks. mind you, there are other members of this fraternity (who might own r32 gtrs.. might be white...) who may as well just keep the KY in the glovebox... :confused: i don't even want to know how much out of pocket this person might be!!! haha
d
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1423856
spotted my mate telling me a R33 rolled yesterday at the Round about near lanyon. he said it was white, tried to drift around a corner, hit a gutter and then flipped. when i drove past today, all i could see was a big black mark on the gutter on the outside of the roundabout as if you were heading towards gordon (turn right towards tuggas, left toards lanyon or u-turn back towards calwell) i dont know if he was lying or not, anyone car to shed some light????
also spotted a gun grey R32 GTR on the same road, gave thumbs up and then a grey R33 gtst in tugags
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1424302
probably defects too...but mostly, they are checking for out of date rego..
I got done on Hindmarsh Dr a few weeks ago....same set up as what you described.
my rego was a few days overdue, I had to leave the car on the side of the road. All the other cars sitting there were for the same thing.
Anguss...that doesn't sound good ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1424626
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
