Spotted a silver S2 R33 with massive chromies going into belco mall about 4, and then passed a dark coloured (it was night) R32 on my way back from gungahlin. also i think MIVEC went past me. it was a silver FTO with a massive wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1487834
To my knowledge it was purchased locally buy a certain someone who used to own a gunmetal R32 GTR with Avo turboworld stickers down the side of it... :)
EDIT: I could be wrong though, but I know in the last week a white R34 GTR V-Spec II has been added to the Canberra lineup :) Seems like theyre becoming a bit more common now prices have slipped on them.
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1488401
Nah same car, i think its the guys girlfriends car, its usually parked at BDL fyshwick. I tend to never see a girl driving it but...
Dayne
It's her's I hope she was driving it cos I certaintly havn't driven it for a while i don't think, and she drives it every where I'll have to tell her you think she looks like a guy. I hardly every drive hers cos I got my shity banged up burgendy one goes faster :) where'd ya see it by the way was it saturday morning and you drive the black one???
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1488648
Technically not a real "spotted" but anyway.....
Brian Hall Autos in Phillip have an R34 for sale in their showroom, it's a GT-t, they seem to think it's a GT-R as that's what they're referring to it as, and they've got an asking price of $45,990 on it.
I love car shops that don't know what they've got....
The funny problem is that it's too cheap for a GT-R and a bit rich for a GT-t :D
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1488883
To my knowledge it was purchased locally buy a certain someone who used to own a gunmetal R32 GTR with Avo turboworld stickers down the side of it... :D
EDIT: I could be wrong though, but I know in the last week a white R34 GTR V-Spec II has been added to the Canberra lineup :D Seems like theyre becoming a bit more common now prices have slipped on them.
that bastard!!!!! a 700horse 32 just wasn't enough was it. that is without a doubt the nicest 34 i've ever seen. and damn cp039's too!!!! its just not fair!!! *stamps feet. flails arms around and goes and sooks in the corner*
the only 34 that might tempt me otherwise would be volk's 750ps demo car. see attach and clicky.
https://www.sau.com.au/forums/topic/30059-spotted/page/189/#findComment-1489168
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
