2 R33's at the big roundabout in Woden about 20 mins ago on the way home.... a white one with a silver bonnet and driver's side front guard, and another silver one with a lip style rear wing flying up the bus lane.....
And a white R33 GT-R on Hindmarsh Drive a few hours ago
And a silvery blue turbo R31 Pintara on Adelaide Avenue.
Edited by Bluprint
https://www.sau.com.au/forums/topic/30059-spotted/page/206/#findComment-1586213
Spotted djhatton's blue R32 GTR parked on Bunda Street in Civic about lunchtime today.
indeedies.
saw a maroon 33 gtst with a loud as bov turning off bunda st towards braddon today.
oh and i'd like to inform everyone of canberra's newest member to the fraternity. if everyone can cast their minds back a few issues to the issue of hpi with the silver 33 vspec gtr from autostyle w/purple chrome te37s, gt-rs turbos, massively over-engineered cooling system and HAAAWT leather trim... well it now belongs to a bloke here in lil canberra.
he was in at inline having his hks hyper-d's swapped over for new bilstein coilovers and a whole lot of trick suspension links/arms/etc from luch (tune-agent... the bloke with the nuts 300zr). he knows all about the friday meets now and i've convinced him to drag it out so you can all see the beast.
it is quite simply a stunning car. up there with andre and mick's 33's. and very tastefully thought-out.
d
https://www.sau.com.au/forums/topic/30059-spotted/page/206/#findComment-1586282
Spotted a heap of R33's in civic tonight...most noteable was andrews car taking off from a set of lights. i dont think the new owner likes the clutch much haha ;)
Haha! It is quite a bit different to a Mazda 323 clutch!
Spotted Ye-Olde-VeilsideR33 on Hindmarsh Drive about 7pm
Yep. That was me also!
I saw a maroon R33 in Civic yesterday around 2pm on the london circuit lights... no idea who that was!
https://www.sau.com.au/forums/topic/30059-spotted/page/206/#findComment-1587252
spotted amaru today in tuggers. didnt see me though.
Where were you at?
Also spotted red R31 with big front mount heading towards Gordon/Tuggeranong (cant remember the name of the street, but it runs past calwell, isabella, richardson)
https://www.sau.com.au/forums/topic/30059-spotted/page/206/#findComment-1588289
Spotted a mangled silver R33 GTSt on the road from the Airport to Queanbeyan at the turn off for the driver training place... looked like it was a 3 car accident involving a commodore, commodore ute and the skyline... hope it was no-one off here :D (yesterday afternoon)
https://www.sau.com.au/forums/topic/30059-spotted/page/206/#findComment-1592731
yup...i experianced that at the rally of canberra earlier this year. 4 am in the morning, your doing security for service park at driver training cetre and its dead silent cept for you talking. you hears the thing come screaming down the road and stop in about 2 metres. its idiling and then it takes of to go and park. damn madce my weekend
https://www.sau.com.au/forums/topic/30059-spotted/page/206/#findComment-1593349
Thats not a diablo, its a gellardo... Diablo had the quad cam V12, I heard one down in Melbourne scream off to beat an orange light and it was just awesome... pisses all over the sound of a ferrari any day
i resent that statement! you're either a lambo man or a ferrari man. i'm most certainly the latter.
:D
d
https://www.sau.com.au/forums/topic/30059-spotted/page/206/#findComment-1593514
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
