Yeah, it seems he has been all over canberra today, i couldnt get over how damn nice the car was... it had gold rims, gold badges, carbon here and there too, your right on about the car... and damnn i would hate to think how much that car could of possibly costed. Does anyone have any pictures of it, i would love to get my hands on some!
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/209/#findComment-1605351
Thanks for that mate:D
There is certainly alot of F355 ferraris in canberra but, a friend went in one to her yr10 formal at grammar on friday night the same night another F355 ferrari dropped someone off at the marist formal.. and none of them were F1.
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/209/#findComment-1606029
Spotted Nik.
Just saw you drive through Tuggers, funny thing was a P plater in some old beater got pulled over by 3 cops and defected just seconds before you passed (complete with exhaust fumes all over your rear bar).
Oh the irony!
https://www.sau.com.au/forums/topic/30059-spotted/page/209/#findComment-1606404
Spotted Nik.
Oh the irony!
Haha and I was driving like a complete tool beater too :(
https://www.sau.com.au/forums/topic/30059-spotted/page/209/#findComment-1606567
Yes, Ian owns the 355 as I was dating one of his daughter's friends.
Funny story actually, when he went to take me for a drive, the battery was flat as it doesn't get driven that much and he had to jump start it with their echo. How funny did that look, a Ferrari running jumper cables to an echo!
https://www.sau.com.au/forums/topic/30059-spotted/page/209/#findComment-1606894
Anyone been to Star City lately?  There's a red 360 Modena usually parked where the valet drop off is. Owned by the guy that lives in the Penthouse there, old guy with a g/f prob half his age. Make that 1/3.
He gives this 360 heaps when he goes, absolute gutsfull.
I saw that there about 2 years ago!! i love 360 Modenas...i wish he'd given it a gutfull when I was waiting there!
https://www.sau.com.au/forums/topic/30059-spotted/page/209/#findComment-1607331
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
