Spotted (and continue to spot) andrews old "Veilside R33". I will try and remember your actual name so i can use it. Yesterday it was at the "G", how did you get the car down in to the underground park? It must have a decent ride height clearance to make it past the mount everest style down ramp? Mine would never make it. Lucky i was in the taxi (commodore) and it wasnt a issue.
Well the name is pretty easy ... Andrew as well (toonz obviously on here). Yeah it actually gets down there quite easlily, was VERY cautious the first time but no troubles. :O
I keep spotting a heap of skylines driving just from work to home. Can never remember when or where in particular though!
https://www.sau.com.au/forums/topic/30059-spotted/page/218/#findComment-1641049
I spotted djhatton @ servo in Kingston too...
Thank you Mate, But i might your say is f@$ken FANTASTIC!!!!!
mmmm they are aren't they. they're absolutely sexual.
spotted ib6ub9 today at kingston servo for a good ole chat. keep your eye out for one great-looking 32, for those that haven't seen it!!!
d
Edited by ib6ub9
https://www.sau.com.au/forums/topic/30059-spotted/page/218/#findComment-1642416
Spotted a nice yellow r34 gtt out back of mitchel, then spooted my worst driving ever when i gave it a hit hen realised i need to turn and had to cut across 3 lanes under hard brakes.
I would imagine the driver and passenger of the 34 would of said something along the lines of "what a dick" coz thats what i would of said if i was them.
https://www.sau.com.au/forums/topic/30059-spotted/page/218/#findComment-1642595
spotted Terminal last night, can't remember where, but i saw ya ^_^
your getting spotted everywhere!
Sweet, sorry mate i didn't see you. were you up in braddon late last night? i popped through for a quick cruise on my way home. other than that i just love to drive i guess :(
https://www.sau.com.au/forums/topic/30059-spotted/page/218/#findComment-1642767
I got the stag with the wing, yep!
Spotted a silver stagea like mine, but Series 2 in woden just outside the computer fair thismorning, looked sweet as
also spotted numerous skylines around civic/woden area, mostly R33's but a couple of 32's. nice day for driving i think
https://www.sau.com.au/forums/topic/30059-spotted/page/218/#findComment-1643082
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
