Spotted Terminal also in braddon on friday night...
I was the crazy fool waving my hands across from Gregorys ford...
I think you saw me?
Also Shell in belco on friday night, spotted a Silver 32 with Vertex kit... Chick driver.. i think your on the fourms..
https://www.sau.com.au/forums/topic/30059-spotted/page/219/#findComment-1644644
I think you saw me?
Ah so that was you. yeah i did see you, but i couldn't make out the group
https://www.sau.com.au/forums/topic/30059-spotted/page/219/#findComment-1644794
Yeah I saw that too.
Black one just near the front doors?
yup that was the one. also spotted a burgandy 33 s1 with chromies this arvo on erindale drive is that what its called ??? i dont know heading from tuggers to erindale anyways
https://www.sau.com.au/forums/topic/30059-spotted/page/219/#findComment-1644854
I think you saw me?
I saw you in Bradon, driving but, not waving. I saw lots of skylines though, i was parked at mobile
https://www.sau.com.au/forums/topic/30059-spotted/page/219/#findComment-1645483
