exchanged waves with a bloke in a white R33 vic rego at the lights on Bunda and Akuna sts in civic last night
Also follwed by a red R33 along athlon this arvo, blonde girly driving, Shell?
Ya that was me:)
Saw DJ hatton in manuka today too
and also grey R32 GTR in Dickson haha said he put on over 1bar boost... took off up the road to dicko
R33 Gts-t in dickson
R33 GTR with gold rims V NICE in dicko too
was line city in dickson tonight
https://www.sau.com.au/forums/topic/30059-spotted/page/226/#findComment-1674567
I think that was me! I was back a bit in traffic? Heading to the hyperdome?
if so, that was you I posted about....(back on the other page) :D
https://www.sau.com.au/forums/topic/30059-spotted/page/226/#findComment-1675407
spotted - heaps of lines (2x white 33's 3 x32's, a 4 door 34) at stonefest last night.
and god do i feel rough!!!!
d
Ill lay claim to one of the 32's And damn did i fret about parking there all night. But it survived unmolestered
https://www.sau.com.au/forums/topic/30059-spotted/page/226/#findComment-1675747
spotted heaps of nice cars today around erindale....... (well, only 4!!!)
let me see:
a black s1 R33 with a GTR wing
a really neat black s13 with ploished silver wheels
an extremely neat R32 4 door with kids and all in the back! great choice for a family car!!! :(
an RX3 with a full cage and what i reckon were 315's on the rear wheels!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/226/#findComment-1676542
Spotted a stock looking purple R33 GTR with A.C.T. plates at Croydon, looks like another weapon from Croydon residing here. Apparently having a big engine and turbos installed. Anyone we know.
nope not that i can remember, any of us know that purple GTR guys
https://www.sau.com.au/forums/topic/30059-spotted/page/226/#findComment-1676698
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
