looks like i've been hearing bullshit shell :P
detomaso pantera, i got the ford thing right though!
http://www5a.biglobe.ne.jp/~supercar/CARS/...aso_pantera.jpg
That car right there is NUTS!
A mate told me about it during one of the formals.. Its apparently got a rear mounted 351 V8 engine, with 4 carbys (1 carby for every 2 cylinders for those playing along at home). Its also a 4V engine, which was explained to me as having 4 valves per cylinder, as apposed to 2 valves in the ordinary 351. Because its rear mounted, it creates an amazing amount of power... and noise...
I just want one.
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1786065
that thing is always at chisholm shops...blue/grey two tone wit ugly rims n kit and a rexy scopp :)
spotted long on isabella drive today around 10:30ish...dude thoise rims look like chromies now...nice n shiney (you got them cleaned yeah?)
yeah that was me, I had only just washed the car..Im not really into chromies but yeah they look heaps better
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1786187
Spotted some FAG*OT in a commonwhore with his mates, cut me me off, then proceed to blast their horn at me after cutting me off, then without any other warning, giving me the finger constantly over the next 30 seconds! MOTHER FUC*ING FAG*OT!!!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1786618
Either way, all the skylines looked very tight, specially yours steve and another wine red r33 with a drift style wing. Are your front gaurds custom steve? the whole kit looked real nice, and different too?
Dayne
yeah wine red was me was meant to have the same gaurds as steve but ran out of cashis after some much needed panel beating like my car looking nice and sleek anywayz
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1786856
looks like i've been hearing bullshit shell :angry:
that's the one!!!!!!!!
http://www.panteracars.com/mont2002a13.jpg
this is just like the arse end that I saw....badges are kinda obvious now I know what it is!!
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1787882
I just want one.
they are a great looking car, 4V refers to the design of the head - the intake port has a greater volume than the 2V. not sure anyone makes a 4 valve head for the 351. came standard with a 4bbl, common set up is to use downdraft carbies like moffat had on the mustang and the falcons for a while. looks truly amazing.
a friend had one, you could just get a coke can sideways under the rear cradle.
de tomaso also made the mangusta, another great looking wedge style.
http://www.motorbase.com/profiles/vehicle/...64;p=1126634563
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1791708
Saw a white R32 with black rims going down Mort Street in Civic. Saw from my work window :D I think he stopped for maccas too.
And while out at Ed's today, saw an awesome looking R33 GTR with paint that looked black from afar but was actually very deep purple up close... Ed was about to put in a RB26DETT which I saw at various stages at Ed's while making a few trips out there over the past few weeks. Swap ya for mine :O
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1794312
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
