I've got 18" shadow chrome rims on my line, though wouldnt mind 19's.
Rach - I was in a rush to get home, as i was just going past to drop a mate home. I had to get up at 1am to start work at 2am:( And i think it was like 930ish already. Your line looked very nice parked there.
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1807208
Don't get me wrong, I have 18" and I want 19's soon. Just not wogish bling rims. They shouldn't be on Skylines nor should big wheels like 20" unless they're like a show car or something, but thats just my opinion :D.
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1807251
*gets ready to run from all the chome fans*
Nath knows the score leave your chomies for the bmw's and show cars :D skylines are generally meant to be a performance car how does adding 50kgs at each corner help performance :)
but like my opinion others have differing ones... its your car you put what you want on there if you are only doing it for others then you suck anyways :D
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1807274
i reckon beemers look awful with bling. its so unfortunate that german cars get hit with the bling stick when they can look great when a bit of race-style/jdm influence gets into their guards.
if i had to have bling, it'd be some nice diamond cut 2/3 piece rims. DEFINATELY no chrome.
d
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1807328
Spotted Jayce and Erica in the Forester out in Gordon looking at purdy Christmas lights, that WRX convoy looked pretty cool :D
Thanks! The boxer rumble was in full effect that night...And,whilst you say you were filming stuff,it does seem a little creepy that you were perched upon a grassy knoll...sniper rifle,anyone?!?
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1807533
haha i was nearly the unexpected skyline in that cruise. :blink: i'm sure you met my mate chris (redheaded guy - rexie with MY 003 plates). shame i didn't make it!
d
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1807899
Chrome? did someone say HOT4s??? skylines and chrome wheels just dont match. anyone seen a 34 with chromies? nope, because it would not only look ugly, but some (like me) would consider it a sin.....(not that im religous or anything.....)
polished alloy dish is about as far you'd go (eg: my volks :rofl: )
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1808634
lkuke...i have a poster of a yellow R34 on my wall with chromies! from HPI mag aswell :)
i think all rims look good, depending on the colours of the car and the style of the car g JDM, Show car, pimp, clean etc etc
except for vaults, whatever car has them looks like shit!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1808750
Actually yes, there's a black R34 GT-t with 19" chrome wheels getting around
But I agree Luke, I'm not a fan of chrome either, but each to their own, you like chrome wheels, buy them
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1808763
I've got 18" chromies always get complimented on them heaps reckon they fit my car perfect, would love a set of twenties but yeah each to there own seriously theres some ugly chromies theres some ugly alloys smeh i must admit i really don't like white wheels but i am a big fan of black which you really don't see enough of!!
Edited by Slither
https://www.sau.com.au/forums/topic/30059-spotted/page/255/#findComment-1810323
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
