Was that when another black line was behind me ??? I think i was off in lala land i was to busy trying to find a park it was impossible that night.
ps spotted a red 32 gtst that sounded ok also a sivler s2 33 with ugly chromies on in sydney... oh yea spotted me in sydney for the next two days so no trivia for me :D
If one of those black 33's was parked in Civic then it was mine. I spotted you at the lights on London Cct, at the Northbourne turnoff. Might have seen me cause i was on foot staring at the car while i was on the phone, lol. Looks tough.
One of my mates went back to his car (Subaru RX) last night only to find rear windscreen smashed, someone had tried to rip the speakers on his parcel shelf out. That P's me off so damn much!!
https://www.sau.com.au/forums/topic/30059-spotted/page/282/#findComment-1997417
Woah! Thats the most i've been spotted in a while! And I didnt even get a chance to reply!
Well I guess the more people who get to see it now the better! It FINALLY begins stage 2 of its extreme makeover tomorrow!
I've spotted a few lines recently. My memory is fading though! Most of the gunghalin crew, you know who you are. Got some good wave to wave relationships happening up north now!
https://www.sau.com.au/forums/topic/30059-spotted/page/282/#findComment-1997485
spotted a few in fyshwick his morning, red 32 at newgel, silver 33 at used car shop down the road from supercheap, and white 33 at CEA tech.
also for jayce http://www.ozzytyres.com.au/images/hall_of...hof_1339_bg.jpg
Shhhiiitttttt! what the fu** happened to the buddy clubs? those look nice, but what about the buddy clubs???
https://www.sau.com.au/forums/topic/30059-spotted/page/282/#findComment-1999112
had a phone call last night from a mate, asking weather or not i had been in an accident, as she had seen a white 33 on kingsfordsmith drive / Ginninderra drive last night.
Aparently was very bad jaws of life were being used. Hope noone was hurt to bad. Was it anyone off here??
https://www.sau.com.au/forums/topic/30059-spotted/page/282/#findComment-1999800
Delayed "spotted"-Scooby driving home in his GT-R and NOT running over the silly shaved lycra clad cyclist on his way home in Jerra' on Wednesday night!
Spotted a yellow 32 at the Monaro RC airfield,and a dark blu 32 GT-R in the middle of the day near the new jail site,same bit of Monaro Highway...
Hey Jayce, the yellow 32 was mine I was out flying getting ready for our big Scale Competition coming up in a few weeks.
https://www.sau.com.au/forums/topic/30059-spotted/page/282/#findComment-2000601
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
