Theres a 35 model Stagea aswell, but I don't think we can get them here.
Yeah M35, comes with VQ25DET and awd of course. all auto's which is a bummer. compliance isn't available yet but i'm certain they're working on it. they look ugly stock, need to get one kitted before i'd consider buying them. also all the hassle i went to with my manual conversion i don't think i could do it again
https://www.sau.com.au/forums/topic/30059-spotted/page/304/#findComment-2186519
woot spotted a hot house green (i think thats the color) r32 with veilside front bar on south st yesterday.
OMG sex on wheels. if you own this car or know the owner can u please send pics to me :thumbsup: i want to put it as my desktop wallpaper haha
i was in teh black silvia with the big wing and veilside front bar.
<3 steve :wave:
Edited by KLowN
https://www.sau.com.au/forums/topic/30059-spotted/page/304/#findComment-2189183
Haha well today i was at dickson then went out to Fyshwich to see my mechanic, so its kinda near mitchel :-p. Where were you hiding?
I was in a Datto 1200 ute (white) I think it was you, or you have a twin 33 out there.
G.
https://www.sau.com.au/forums/topic/30059-spotted/page/304/#findComment-2190999
Spotted this morning near Woden, Urban Services killing puppies. Kia vs. Puppies. Not pretty.
Spotted the yellow R34 and pir8ter near Woden this morning.
Yeah, that was me. I was staring at the car so i didn't see you but my gf said you waved, so sorry for not waving back! Car looks good mate!
https://www.sau.com.au/forums/topic/30059-spotted/page/304/#findComment-2192558
Well no skylines in Amsterdam or Brussels but i have seen a few WRX's, nissan sunny's + pulsars lol On a better note and one that i find funny as is pretty much all taxies are mercs a couple even had 18's lol. Also saw some fancy arse car i am not sure of the name but it was one of those $300,000 + ones. I have also seen probably every model of audi, merc and bmw including a very sweet looking black BMW M5 :)
anyways Leech_ out from Brussels
https://www.sau.com.au/forums/topic/30059-spotted/page/304/#findComment-2199567
Spotted: Some goose reversing into the front of my car while I was sitting in it in Civic.
It's as if he just threw it in reverse and started rolling without looking, before I knew it there was that not so pretty cracking noise that fiberglass loves to make.
https://www.sau.com.au/forums/topic/30059-spotted/page/304/#findComment-2199621
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
