i spotted a white R33 gts-t with white wheels, M-spec kit (skirts anyway...) and an exhaust going southbound along adelaide ave this morning at around 9.45am ish.
also spotted a mysterious looking black R32 gts-t heading north along adelaide ave this evening at about 9.30pm ish. it had a bodykit of some kind and black wheels. it was dark, so i couldn't see it properly, but man it looked hot!
and lastly, i saw Rachel going up yamba dr towards woden shortly after i saw the black R32. i waved, but i was in my R31, so i didn't expect you to notice me. had i have been in my R33, well that would be a different story...!!! HA! :)
https://www.sau.com.au/forums/topic/30059-spotted/page/335/#findComment-2538648
Spotted a gold 33 with a big fmic and a flush bootlid on the way home from work. Looked awesome. Possibly had a black/carbon bonnet too... Don't really remember now. Anyone else seen this around?
Could be the same one I have seen out at Jerra. Very nicely done isn't it.
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/335/#findComment-2541019
Spotted that one lastnight cruising around braddon and civic - gave a wave and a nod, got one in return.
Looks nice as!
https://www.sau.com.au/forums/topic/30059-spotted/page/335/#findComment-2541743
In Fyshwick earlier today????
Jayce? >_<
Mmmm...32 goodness! Is there anything better? I think not!! Heard you two were up to no good,LOL!
Also spotted a black 32 with nice shiny rims,followed by a black 33 with nice shiny rims,driving across Dairy Flat Road towards Fyshwick about 5.45 yesterday arvo';looked like formation driving in an overly police-aware state...
https://www.sau.com.au/forums/topic/30059-spotted/page/335/#findComment-2543016
