Had a blue R32 sedan with a cannon zorst behind me on the parkway this morning, but wasn't paying attention and didn't realise it was a 'line until it passed me in the right lane and I saw the taillights ^^;
May of been the same 32 id seen...
Blue with gold/Bronze wheels... i was heading the other way..
https://www.sau.com.au/forums/topic/30059-spotted/page/344/#findComment-2594283
Spotted a black R33 in Queanbeyan parked behind the car wash and also while putting petrol in my car I spotted a nice Marone R33 with a black 400R front bar driving and the driver waved and I waved back :dry:
Black 33 is mine :P Didn't see you, probably would have been at work. Spotted a black R33 S2 on the way to queanbo, Vic rego i think, driver didnt wave though. Also spotted a black 33 S2 on the way home, FMIC, that you Leigh? only caught a glimpse, driver waved i think i got a half assed last second wave in though. Looked tough!!
https://www.sau.com.au/forums/topic/30059-spotted/page/344/#findComment-2595466
Spotto'd a black S2 R33 on Parkes Way this morning into Civic, thought it was Leigh but upon closer inspection via the rear view mirror Leigh's car doesn't have mesh through the front bar & white mags :dry:
https://www.sau.com.au/forums/topic/30059-spotted/page/344/#findComment-2595756
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
