I was turning into Gowrie you wouldnt have seen me i was in the massive line on the other side of the road trying to get into the tuggeranong area lol only saw you through my rear view mirror
Guilty as charged!!
I saw a 180 but it looked goldish to me. Didn't see you Leigh, where were ya??
https://www.sau.com.au/forums/topic/30059-spotted/page/348/#findComment-2619351
Spotted last night at around 6:40pm on erindale drive from tuggers heading towards woden.
1 Gray R32 gtst and 1 Gray R33 gtst.
A p-plated blue commodore ute cut off the Gray R33 and the R33 chased after it going fairly fast. Next thing I see is a big smoke cloud as one of them locked up their brakes as there was a mobile police camera van there.
anyone here? what was the full story?
I was in a white R32 gtr with white TE37's and no wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/348/#findComment-2620383
Is your skyline the one that I see a lot of the time at Centrelink TOP in Tuggers? If so, nice GTR.
Yep, I've seen your car there aswell, very nice paint job and rims.
there are at least another 2 skylines there, black R32 GTST and black 4 door GTS (I think)with pink fluffy bits inside.
Can almost start a Centrelink Skylines Club, haha.
https://www.sau.com.au/forums/topic/30059-spotted/page/348/#findComment-2620858
Spotto'd MIVEC near Swinger Hill twice, just after 12 and just after 12:30
You may have seen me waving at you from inside a white Pintara TR-X[.quote]
Nah didn't spot you, did see your car out the front when I got home last night.
I was buying flowers for the missus.
https://www.sau.com.au/forums/topic/30059-spotted/page/348/#findComment-2622226
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
