I was turning into Gowrie you wouldnt have seen me i was in the massive line on the other side of the road trying to get into the tuggeranong area lol only saw you through my rear view mirror
Guilty as charged!!
I saw a 180 but it looked goldish to me. Didn't see you Leigh, where were ya??
https://www.sau.com.au/forums/topic/30059-spotted/page/348/#findComment-2619351
Spotted last night at around 6:40pm on erindale drive from tuggers heading towards woden.
1 Gray R32 gtst and 1 Gray R33 gtst.
A p-plated blue commodore ute cut off the Gray R33 and the R33 chased after it going fairly fast. Next thing I see is a big smoke cloud as one of them locked up their brakes as there was a mobile police camera van there.
anyone here? what was the full story?
I was in a white R32 gtr with white TE37's and no wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/348/#findComment-2620383
Is your skyline the one that I see a lot of the time at Centrelink TOP in Tuggers? If so, nice GTR.
Yep, I've seen your car there aswell, very nice paint job and rims.
there are at least another 2 skylines there, black R32 GTST and black 4 door GTS (I think)with pink fluffy bits inside.
Can almost start a Centrelink Skylines Club, haha.
https://www.sau.com.au/forums/topic/30059-spotted/page/348/#findComment-2620858
Spotto'd MIVEC near Swinger Hill twice, just after 12 and just after 12:30
You may have seen me waving at you from inside a white Pintara TR-X[.quote]
Nah didn't spot you, did see your car out the front when I got home last night.
I was buying flowers for the missus.
https://www.sau.com.au/forums/topic/30059-spotted/page/348/#findComment-2622226
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
