Spotted me being pwned by a CRX off the lights... (i fluffed the launch bad, ask MANG)
dont laugh, its not a normal CRX. If you see a black CRX siR with mesh wheels you better have something to back yourself with coz it is QUICK!
https://www.sau.com.au/forums/topic/30059-spotted/page/374/#findComment-2840333
A dark r32 heading back from civic about 545 this arvo.
Also a white 32 heading back to lanyon.. had it front bumper taped on? I was driving my dads camry and thought it would be weird a camry driver waving to you. haha..
https://www.sau.com.au/forums/topic/30059-spotted/page/374/#findComment-2843435
Just passed rego. i was accused of all sorts of underhanded tactics such as removing globes from my dash cluster to hide certain lights...
but i passed, so it doesnt matter. plates on it thursdaY!!! YEE HAW!!
i was accused of using a shadey engineer to get all my bits engineered.
the jury is still out whether or not he's shady, but its registered!
https://www.sau.com.au/forums/topic/30059-spotted/page/374/#findComment-2845482
YAY! I love those moments..! Well, I cant speak as I've yet to pass.. can someone else take your car thru the pits? :D
https://www.sau.com.au/forums/topic/30059-spotted/page/374/#findComment-2847106
YAY! I love those moments..! Well, I cant speak as I've yet to pass.. can someone else take your car thru the pits? :(
yeh they can. I was tempted to get my GF to take my car over but coz its on permit only I can drive it on the road.
its over and done with now anyway :) hooray for rego!
https://www.sau.com.au/forums/topic/30059-spotted/page/374/#findComment-2847333
Spotted on Monday about 5:15pm, silver R33 with nice looking bodykit going through civic. Only problem, you were ON THE PHONE WHILE DRIVING. not only is it illegal, it's insanely dangerous to yourself and others around you. be a bit more sensible while driving.
https://www.sau.com.au/forums/topic/30059-spotted/page/374/#findComment-2848402
I think I spotted this guy too in Braddon around the same time too.
https://www.sau.com.au/forums/topic/30059-spotted/page/374/#findComment-2848589
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
