^^ That was me, just washed it and waxed it for the first time in weeks. Driving home along Barton Hwy and it starts pissing down so my car got nice and muddy again...
Anyway spotted a S1 33 near Belco at around 4, had decals or stickers on it and was driven by a lady.
https://www.sau.com.au/forums/topic/30059-spotted/page/385/#findComment-2922864
Ah, not techincally My chaser, but I'm driving it and I've had it for about a month. It's my brothers car while my g/f's car is in the shop and she drives my Stagea.
They're nice cars, and they need the traction control they come with I'll tell you that. 1JZ-GTE's are a tough engine.
https://www.sau.com.au/forums/topic/30059-spotted/page/385/#findComment-2923690
Pic's? Wanna drag it 'round to the gathering at this new possible meeting place on Sunday,if you're not doing anything?( http://www.skylinesaustralia.com/forums/in...p;#entry2914496
I've always wanted an up-close-and-personal with a Chaser....
https://www.sau.com.au/forums/topic/30059-spotted/page/385/#findComment-2924186
Yeah I was thinking of coming to that. I might not have the Chaser on the weekend, my brother has asked for it back, in return for my parents VL... yippee, a VL.
Anywho, I'll try and make it there in the Chaser, if not then I'll be there in the Stagea.
https://www.sau.com.au/forums/topic/30059-spotted/page/385/#findComment-2926104
A mate of mine at work has one, i went for a ride in it - apparently its one of the only auto's that will take (and has) a PowerFC.
Its ok, He says its more about the convenience about having 4 doors (he's an ex-supra/soarer guy) and it still has the toyota he loves.
https://www.sau.com.au/forums/topic/30059-spotted/page/385/#findComment-2926368
I spotted a couple of lines in the dirt car park behind Tuggers Car care.. blue 32 and black 33 w/ red rego. And I saw a white 33 drive past me at that bus stop.. I was that loser wearing a pink business shirt sitting on a trolley that I tipped over to sit on... whilst waiting for the bus.
https://www.sau.com.au/forums/topic/30059-spotted/page/385/#findComment-2926517
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
