Nope not me :D I never get to drive during the weekday my girl always get's it . Thats the main reason why i don't know if i need the skyline lol she drives it maybe 80% of the time to my 20%. But if it was me i would have waved then checked out your mrs hehe
leech were you in woden yesterday round 12? if not waved to a black r33 who was more interested in checking out my mrs lol.........
https://www.sau.com.au/forums/topic/30059-spotted/page/393/#findComment-2980437
Nope not me ;) I never get to drive during the weekday my girl always get's it . Thats the main reason why i don't know if i need the skyline lol she drives it maybe 80% of the time to my 20%. But if it was me i would have waved then checked out your mrs hehe
im sure the Mrs is attractive and legal, unlike the guy with his two mates in the white R33 i saw up Canberra avenue at lunch turning in towards St Claires to pick up minors.. Good work guys!! :rofl:
Edited by 350zon20's
https://www.sau.com.au/forums/topic/30059-spotted/page/393/#findComment-2980994
im sure the Mrs is attractive and legal, unlike the guy with his two mates in the white R33 i saw up Canberra avenue at lunch turning in towards St Claires to pick up minors.. Good work guys!! :laugh:
What gives you the impression they were minors? St. Clares goes up to Yr 12 so im pretty sure there are lots of 17 and 18 year olds.
https://www.sau.com.au/forums/topic/30059-spotted/page/393/#findComment-2981764
If there's grass on the wicket,you can play cricket...Oh,did I just say that?!?
https://www.sau.com.au/forums/topic/30059-spotted/page/393/#findComment-2982052
*searches around for clever sayings* When in Rome...... wait, that doesn't apply here, dang! I was trying so hard to be cool, too.
Spotted: Me; about to hop on a plane.....For an all expenses paid trip to the F1's! Including access to all areas, guest of the Ch10 corporate box, dinner at the private room of Jamie Olivers restaurant "15" and various other goodies....life is sweet! See ya'll fu**ers on Tuesday when I arrive home!!! :(
https://www.sau.com.au/forums/topic/30059-spotted/page/393/#findComment-2982545
Spotted a white VT with clear tail lights Trying to be a hero and cut me off, dead set cut across two lanes to make an exit. what a ledgend if someone knows him they should shake his hand and then brake his nose
sorry guys i got bored so i drew a picture for yas lol so you can feel my rage
Edited by loymclure
https://www.sau.com.au/forums/topic/30059-spotted/page/393/#findComment-2983423
I Saw Rachel and her skyline on the side of the road this morning, just exiting the parkway on my way to Bruce. I would have stoped to help, but it looked as someone else was already helping you out. Hope every thing is ok!
https://www.sau.com.au/forums/topic/30059-spotted/page/393/#findComment-2984020
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
