spotted an extremely dirty white r33 heading into the city along canberra ave around 12pm, being driven by blonde who thought she was to cool for school....
also saw leech yesterday in fyshwick, giving his engine a good rev at a set of lights...
https://www.sau.com.au/forums/topic/30059-spotted/page/417/#findComment-3194891
Spotted a rather Tidey Blue R33 (i think) At the fyshwick markets gave him a wave and a tip of the ol head and he replied.... unsure if he knew why i was waving at him lol...
Edited by loymclure
https://www.sau.com.au/forums/topic/30059-spotted/page/417/#findComment-3195430
Spotted gunmetal R32 GTR at Repco fyshwick. A white R32 GTR at Bunnings.
Spotted another gunmetal R32 GTR being flogged at Newcastle St.... I have a feeling that that might be mine that I'm supposed to pick up tomorrow. ;)
I think that gtr u saw at bunnings maybe shredder?
And that feeling that you have seeing your car being flogged is a feeling i can empathise with.. not a good feeling. Not saying its gonna be yours.. but it'll be a long 24hours. hahah
https://www.sau.com.au/forums/topic/30059-spotted/page/417/#findComment-3196843
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
