Spotted a Red 32 right near the pedestrian crossing outside Subway on Emu Bank Road, got a wave and gave one back. I'm pretty sure the guy works at a place in Belco and has helped me purchasing the right products a couple of times(Don't wanna give away too much of where he works).
Spotted a white R33 followed me the whole way from Woden, down the parkway and then turned off at Kambah.
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3453100
Spotted
Yesterday
Silver 33 Sedan heading Yass way on Barton Hwy around 5:30pm
Black 33 On Barton ACT side
Silver 33 GTR parked near BP woden with cameras around 5pm
White 34 Sedan on Athlon around 12pm
Also spotted some poor bastard blowing something in his reasonably new Peugot. He was parked on the side of Athlon (near woden) this morning with white smoke absolutely billowing out, idiot didnt turn off his engine, just put his hands on his head and start walking back and forth.
Edited by Baconer
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3453120
white GT-T sedan would have been Abo Bob & me
and yeah we saw the Pug too! It looked like the oil was all dumped on the ground and was burning and yeah how much smoke was there!!... dunno what happened exactly!! poor guy!
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3454355
on saturday i drove past a black 33 with red plates, female driver leaving the brand depot, then i parked adjacent to a blak 33, white rims, 40th aniversary badge.
then today i spotted a gunmetal 4 door parked in front of tuggers lifestyle centre/tuggers markets/good guys building.
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3454812
Hmmm wonder what Tuk Tuk (Mark) was doing at tuggers lifestyle centre :D
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3455473
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
