Hot bayside blue R34 (not sure if GTR or not), coming off Belconnen Way towards Bruce (the Hospital). 4 door silver S1 R33 close behind, same direction on the same green light. Far out we're common hahah
Hey matey... i think the R34 was me - i work around that area, and would have been driving there this morning at around 8:30am or there abouts? it's an R34 GTR V-Spec II - Bayside Blue..
What were you driving? I'll look out for you next time and make sure to wave a hello!
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3733389
Hey myr332, were you cruising up Parkes way this evening at around about 6(ish)? I think I saw a Bayside Blue R34 GTR pass me on my way home.
sure was.. dealing with traffic destined and from Quenbeayan... it's like being back in Sydney traffic again!
what's your ride?
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3733814
You've been here since 2003 and only made 63 posts!?? WTF :D
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3735563
Spotted a very very nice black 33 with gold (BBS?) rims and what appeared to be a CF bonnet. Had NSW plates, older chap with lady friend parked near Bunnings Tuggers.
I was returning to work and parked behind you.
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3736268
You've been here since 2003 and only made 63 posts!?? WTF :)
haha.. yeah :) previously owned a Red R33 GTS-T, and posted allot during that time - and then fell off the scene. of course i have reinvigorated my interest by purchasing my new toy, and moving to canberra!
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3736741
Spotted a smashed up Magna on Gungahlin Drive extension... Obveously though the wall was some interdimensional portal to the pub...
haha i spotted a maroon Camry on the same road tonight
was kinda half up an embankment with the door hanging open, couldn't see what damage it had exactly
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3739569
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
