Hot bayside blue R34 (not sure if GTR or not), coming off Belconnen Way towards Bruce (the Hospital). 4 door silver S1 R33 close behind, same direction on the same green light. Far out we're common hahah
Hey matey... i think the R34 was me - i work around that area, and would have been driving there this morning at around 8:30am or there abouts? it's an R34 GTR V-Spec II - Bayside Blue..
What were you driving? I'll look out for you next time and make sure to wave a hello!
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3733389
Hey myr332, were you cruising up Parkes way this evening at around about 6(ish)? I think I saw a Bayside Blue R34 GTR pass me on my way home.
sure was.. dealing with traffic destined and from Quenbeayan... it's like being back in Sydney traffic again!
what's your ride?
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3733814
You've been here since 2003 and only made 63 posts!?? WTF :D
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3735563
Spotted a very very nice black 33 with gold (BBS?) rims and what appeared to be a CF bonnet. Had NSW plates, older chap with lady friend parked near Bunnings Tuggers.
I was returning to work and parked behind you.
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3736268
You've been here since 2003 and only made 63 posts!?? WTF :)
haha.. yeah :) previously owned a Red R33 GTS-T, and posted allot during that time - and then fell off the scene. of course i have reinvigorated my interest by purchasing my new toy, and moving to canberra!
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3736741
Spotted a smashed up Magna on Gungahlin Drive extension... Obveously though the wall was some interdimensional portal to the pub...
haha i spotted a maroon Camry on the same road tonight
was kinda half up an embankment with the door hanging open, couldn't see what damage it had exactly
https://www.sau.com.au/forums/topic/30059-spotted/page/472/#findComment-3739569
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
