Just met a guy called Chris/John (shit! I suck with names, think it was John) at the carwash at the top of Belco. Nice black R32 mate, join the forum!
Spotted new me needing new brakepads front and rear after Wakey today... ouch. I was doin' consistant 1.20s.. it's a start.
https://www.sau.com.au/forums/topic/30059-spotted/page/480/#findComment-3830582
did the black 32 have stock wheels on the back and i think gold calipers?
edit: yeah thats john, he just called me, ive been nagging him to join the forum for ages heh.
Edited by MANG
https://www.sau.com.au/forums/topic/30059-spotted/page/480/#findComment-3830614
spotted a dark 33, barely, southbound on lanyon drv without headlights the other evening..
also spotted dan (33sedan) behind me on lanyon drive a couple weeks ago. surprised he recognised me.. did he mention anything on the forums about a new exhaust?
https://www.sau.com.au/forums/topic/30059-spotted/page/480/#findComment-3832403
spotted my car being driven away into the night...
...on its way to get serviced by a friend in canberra and then put up for sale by this Monday :yes: (only took me 2 months to finally get around to it, had the parts sitting ready but either im busy or friend is busy so doesn't get done)
Edited by Baconer
https://www.sau.com.au/forums/topic/30059-spotted/page/480/#findComment-3833363
kate
i was too lazy to walk over to the rmc store so i drove. where u workin there or dropping stuff off so are in the ADF ??? be sure to say hi next time, i am friendly sorta guy, or at least i hope i am,
cheers alex
hey alex, I am in the army and was picking up polys I got badged and taken in.....work in the dungeons of Russel, where are you? will say gidday if i see you around again for sure.
https://www.sau.com.au/forums/topic/30059-spotted/page/480/#findComment-3839249
spotted black R34 turning into Dickson off Northbourne
blue R32 with front mount parked on Sutton Road
silver R34 with L plates, 2 young guys, driving over Athlon near Mawson
white R33 turning into the southern cross club at Woden, gave a huge wave out my window... he looked a bit confused haha
https://www.sau.com.au/forums/topic/30059-spotted/page/480/#findComment-3840763
Haha! My car is absolutely filthy at the moment, haven't washed it since going up to Temora last Saturday and catching a few big bugs in the intercooler.
Pretty disappointing that we lost the game too, I was over in the hecklers corner. ^_^
https://www.sau.com.au/forums/topic/30059-spotted/page/480/#findComment-3840817
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
